what gears?
what gears?
Ok, I finally got my m6 swap done. It still chatters for the fact I still have the 3.23 gears in still. I am about to do some other stuff and I want everything to work together. I am going to slap a set of the 19x12 07 Zo6 wheels on the back with either a 305-325/30/19.(same height just one wider than other) I am also going to intall a semi large cam, just above .600 lift with a duration between 238-244 @.50 with a lsa in the area of 112. (ex: S cam, Tsp ms3, T-Rex something along those lines) I am leaning towards the MS3 though.
My question is what gears do I need to make my combo of cam and wheel size work for my advantage? The car will remain a cam only car for a long time. I am open to any and all suggestions.
sammyb
sammyb
I'd say a either a 3.73 or 4.10 gear, any more gear and you'd have to really rev it and that tire isn't very tall.
http://www.f-body.org/gears/ You can enter in the combo here. and play with the info, enter max rpm as where you want to shift at, over reving the motor just because it can make it to the finish line without hitting the rev limit doesn't mean it will go faster. Ideally you'll want to hit the finish line in 4th gear with your shift light just turning on.
Depends on the cam, if you go with something you rev to 6700 then you may go with a 4.30 gear, I wouldn't go 4.56 without a taller tire.
I had 3.90 motive performance in my 10 bolt. I always wish I went steeper. Thats why I put the Motive Performance 4.30's in my 9". A few other mfg's makes them for the 10 bolt as well.
ok kewl, I will go with the 390's I think they will be okay or you guys wouldn't use them. I was leaning towards 4.10's. Since now i am aware that i can get the 3.90's for it i will just get them. thanks fellas.
I think anything above 4.10 is too steep for an f-body. the LS1 (stock) doesnt rev high enough to really utilize that steep of a gear IMO. I have a friend with an s2000 whos planning on puttin either 4.55s or 4.77s in his car. His redline is 8000 rpm though not 6200 like an LS1. I think 3.90s are a good daily driver gear ratio. For you guys that either use your cars as weekend cars or summer cars, 4.10s or higher would certainly make the car more fun, but I would never go above 4.10 in my DD. But thats me.
I have a set of 3.90's any i have no complaints at all. They are SO quiet unlike my 3.73's in my v6 camaro which drove me nuts.
Also, my car is a DD and 3.73's wouldnt have made much of a difference and 4.10's would have been overkill IMHO. I feel I have the best of both worlds.
I don't know how tall of tire you are planning on using, but with my stock rims/tires I barely top out 4th in the quarter mile.
Good luck!
I just installed a 12 bolt with 3.73s in my car. The car feels so much faster and it totally eliminated my clutch chatter. I wouldve went with 4.11s but I bought the 12 bolt used and they came with it.
yeah the tire combo is netted to just shy of 26inch in the rear. It will be a cam only car for a really long time. It is my dd, not that i drive across the world or anything. I was thinking 3.73's but its alot from a factory m6 car. I think that 4.10's aren't to much but kind iffy. So the 3.90's are the half way point. So 3.90's are going in. next week maybe.
