Bad Vibration in stick at 3500rpm and above.
Took my car to the dealer for a bad driver side axle bearing and a bad tranny mount to be replaced under warranty and now after 3500 rpm I get a really bad vibration through the stick shift. Is there some type of adjustment on the tranny mount or should I just take it back to the dealer? Or can it be something else? Any ideals or comments would greatly be appreciated.
There's no adjustment that can be performed to the trans mount. It's possible that you're just feeling a normal degree of vibration that you didn't pick up before because of the bad mount. Personally I'd just take it back to them. If you want to trouble shoot check to see if you get the vibration while parked at the RPM you pick it up. If so it's an engine, internal trans, pressure plate, or flywheel balance issue. If you only pick it up rolling then it's a driveshaft, diff, wheel balance, or possibly internal trans balance issue.
