Anyone modify thier own coolant tube instead of getting the later one and plugs?
Are you talking about installing a LS6 intake on a LS1 ?
If so. yes.. I and many have just grinded down the ribs of the under side of the LS6 intake to alow the LS1 coolant tube to fit under the intake. A few others have use two fron tube and connected them with some tubing.
I'm talking about the coolant tube that goes from head to head and then back and to both heads again on top of the valley cover. I thought I read somewhere that the older style tubes could be modified and used by cutting the part that goes to the rear set of tubes and soldering or welding the end together. I am using a FAST 90 and don't desire to modify the intake in any way. I know the newer style tube isn't expensive, but if I can modify mine easily, then I'll go that route.
