Sponsored by: DashLynx
Gauge opinions, thinking Nexus
Old 12-02-2007, 06:05 PM
ShortChevy's Avatar
Default Gauge opinions, thinking Nexus
I'm looking for a couple of gauges that match the factory firebird ones. Black with red blacklight at night. The only ones that seem to fit the profile are the Autometer Nexus line. They are damn spendy, but if that's all there is I guess that's what I'll get. Anyone know of any other gauges that fill the bill. Looking for a trans temp and a wideband.
Old 12-02-2007, 07:04 PM
Fast_94_Z's Avatar
if it were me i would get the led kit in blue from the sponsor on here and then get the cobalt gauges. the nexus gauges are pretty expensive.
Old 12-02-2007, 07:54 PM
dcvingv6's Avatar
I'm kinda in the same boat as you, I'm going to be needing a few gauges soon as well... i was looking at the nexus gauges, and it sucks that you need that controller box or whatever just to get em to work.
That being said, i think im going the the autometer pro comps.
A guy i work with has them in his LT1 firehawk, with a red led in there, they look pretty good. I'm like you though, i'm a stickler to have matching gauges.
I was looking at doing the blue conversion as the guy above has suggested... but i like my red lights too much.
Hope this helps...
--Mike
Old 12-02-2007, 08:08 PM
ShortChevy's Avatar
I hear ya, red lights are a must. My favorite color for guages, even if they weren't red stock they would be by now. I like the Pro Comps, but there not lit though the dial which is kind of a must for me. Anyone else have any ideas?
Old 12-02-2007, 08:34 PM
chrysler kid's Avatar
wish i knew of some, i want to get an aftermarket head unit but only if i can find one that lights up red, havent found any good ones et
Old 12-02-2007, 08:44 PM
BlueBird346's Avatar
What about Sport Comp II, but swap the white LEDs for red ones? Is that possible, because if it is, thats what im doing.
Old 12-02-2007, 08:46 PM
ShortChevy's Avatar
I have the JVC KD-G820. I matches great, the volume **** and all the buttens light up red and the screen and like a dark grey. I think if the screen was red it would be a bit overdone. Alot of the newer JVCs are like this. It looks great at night.
Old 12-02-2007, 08:49 PM
ShortChevy's Avatar
I was interested in this as well but I don't know if you can swap bulbs on that line of gauges. IMO the numbers dont match as well as the Nexus.
Old 12-02-2007, 09:08 PM
not bad, i didnt see infared listed as a spec so i dont think you could use it with your steering wheel controls tho
just in case someone runs across this and asks how do i do that, heres what you need, a pac swix adapter
http://www.crutchfield.com/S-L5tysON...wi%26tp%3d3405
Old 12-02-2007, 09:13 PM
On their site it says you cant, but surely thes some way to swap a LED, right?
Old 12-02-2007, 09:30 PM
ShortChevy's Avatar
I wonder why it's not listed. It does have a remote and I have the PAX for my steering wheel controls.
Old 12-02-2007, 09:32 PM
ShortChevy's Avatar
I would think so but I'm not sure how these gauges are set up, seeing as they only light through the guage the bulb placement may be different then a standard gauge.
Old 12-02-2007, 09:48 PM
dcvingv6's Avatar
I just did some searching, and it appears that you CAN NOT change the color of the sport comp 2 gauges... the LED's are hardwired, and it looks like you just have 2 wires coming out to connect for the back lighting.
Old 12-02-2007, 09:50 PM
ShortChevy's Avatar
Yea I had a sneaking suspicion. Thank you very much for searching though.
Old 12-02-2007, 10:00 PM
So what if the LEDs ever have to be replaced?
Old 12-02-2007, 10:04 PM
ShortChevy's Avatar
I doubt they will ever need to be. LEDs last so long the gauge would probably need replacing before the LEDs.
Quick Reply: Gauge opinions, thinking Nexus
