EXCESSIVE81
12-03-2007, 03:57 PM
i am ordering pistons for an ls3 and can not find the cylinder lenth anywhere. also what is the best piston to deck spec to run withthese motors in a boosted application?
thanks
shane
drain89
12-03-2007, 09:38 PM
Are you keeping the rods also? How much would you want for the pistons and rods?
White_Hawk
12-04-2007, 10:45 AM
Some of the vendors are selling L92 pistons, they should be the same. Otherwise call Diamond, I am sure they are making something.
-Geoff
Beaflag VonRathburg
12-04-2007, 06:45 PM
Why do you need the cylinder length? All you should need is stroke, deck height, rod length, and deck clearance. You measure the deck height, and then plug in what stroke crank and rods you are using. The deck clearance is your choice and you figure the compression heigth from there.
For example:
amount the piston is in / out of the hole aka deck clearance = (1/2 x stroke + rod length + compression height) - deck height
Example:
I like a zero deck for a multitude of reasons... so
0 = 1/2 x 4 + 6.125 + x - 9.240 = 1.115 compression height.
