Pontiac Firebird 1967-2002 - 3800 sries ii oxygen sensor location?
Impackt
12-04-2007, 06:01 PM
I need to change out the sensor BEFORE the cat on my 97' Firebird, which is a 3800 series ii.
Where is it hiding at?
The only place I haven't really looked was under the heat sheilds.
Please help me. :emb:
Rastoff
12-04-2007, 11:09 PM
I searched for a long time to find mine. It was on top of the exhaust pipe in an almost impossible to reach location. The easiest way to locate it is to simply run your hand along the pipe in front of your cat.
Mine is a '96 LT1 so it has two cats and four sensors and is much different than yours. Nevertheless, if you follow the pipe you will find it. These cars were not made with maintenance in mind.
Impackt
12-05-2007, 06:23 PM
After looking under my car today, I noticed that I have 4 sensors. One in each header, one right before the cat, one right after the cat. Now my question is...which sensor can cause the car to run lean?
Is it one of the sensors in the headers, or is it the sensor right before the cat?
Also, what tool is needed to remove a sensor?
Rastoff
12-05-2007, 11:00 PM
Also, what tool is needed to remove a sensor?[/B]
You will need a large wrench to remove the sensor. I used a 10" adjustable wrench to get mine out.
blackls1maro
12-07-2007, 03:22 AM
o2 sensors are usually 7/8". they make special sockets (similar to spark plug sockets) with a slot cutout in the side for the wire.
Impackt
12-07-2007, 05:59 AM
Thanx...I think that's exactly what I need. Nothing else can fit in that tight spot. I guess I'll try to find one today :D
Impackt
12-07-2007, 07:03 PM
Thanx for all the help. I changed the sensor today.
The CEL went off after a few minutes of driving with the new sensor, then it came on a again a few hours later. I stopped by a parts store and erased the code, so I'll see what happens...
blackls1maro
12-08-2007, 01:40 PM
you're very welcome!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
