sticking to the floor on 3rd!
Old 12-04-2007, 11:01 PM
txh0tb0i972's Avatar
Default sticking to the floor on 3rd!
well heres how it starts I bought my car around may... guy said it had all new sync forks slave master and spec 2 .... well i had a problem with my clutch sticking to the floor switching to 4th.... so i decided ill do the drill mod! i did it now when coming up it releases but like it pauses then comes up! kinda weird explaining! so we bleed it for about 30 mins.... did the same thing so we test drove it .... was doing good... 3rd was sticking to the floor .... im trying to see what can be the cause of it... and it only does it a high rpm! thx!
Old 12-04-2007, 11:17 PM
mrhzk35404's Avatar
sometimes your clutch fluid need to be completely changed out
Old 12-04-2007, 11:31 PM
01CaMMMaro's Avatar
what year is your car? 01-02 had the upgraded master and slave, 98-00 have problems. either way i would put all new clutch fluid in, bleed it and see if that works... if it doesnt then its probably your master or slave.
Old 12-05-2007, 07:49 AM
tee-boy's Avatar
Default ddd
I agree w/ the clutch fluid change out. If it is dark colored, it may be a good time to flush it out. It worked for me.
It also works wonders on brakes too.
Old 12-05-2007, 12:11 PM
01CaMMMaro's Avatar
thats because clutch fluid is break fluid hehe
Old 12-05-2007, 07:13 PM
i just changed it like 3 days ago im telling you i did the drill mod and everything is about 8 mths old! its a 99
