Gears & Axles - gear install
wildn347
12-06-2007, 03:25 AM
ive never done one before and am thinking about doing it myself on my 98 ta is it hard to do, or any special tools that i will need or and tricks to know when messing with gears? im going from 2.73 to 3.73
sroach20
12-06-2007, 09:32 AM
http://www.ls1tech.com/forums/showthread.php?t=820834
Jawsgear
12-06-2007, 11:57 AM
Special Tools Needed: Dail Indicator to check backlash, Inch Pound Torque Wrench to measure pinion bearing preload, 1/2 impact gun with a minimum of 150psi pressure, and basic mechanics tools. With the right tools and the patience you should be able to tackle the job without any problems. If you have any questions let me know. Glad to help.
Jeff
99mongooSS
12-06-2007, 12:31 PM
good luck.
keliente
12-06-2007, 12:48 PM
Jeff
A big pry bar and hammer never hurt either!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
