110 LSA for a procharged setup???
Im looking for some opinions on this. Last week i was given the specs of 226/234 110 LSA .560s for what is supposed to be my daily driven 383 Procharged LT1.
Heres the setup:
Fully built 383 LT1 w/ported Trick Flow heads and Intake
Compstar crank/rods/ Ross custom blower piston
Engine should sit around 8.7:1 compression
Jesel Sportsman shaft mount rockers
Procharger running 12-16 lbs on the street w/ front mount intercooler
3400 Vig Converter in a beefed up 4L60e
Now this is a proven shop that i respect, but a 110 LSA seems to go against the norms of a forced induction camshaft. They say it is one that seems to work best for them based on past experiences and they do it because of the relatively short duration. And their cars DO RUN fast. Im just looking for your opinions guys? Any input is appreciated. Keep in mind the goal of this setup is also to be my DAILY DRIVEN car....
Heres the setup:
50
Thats the consensus on a blower motor....dont want to get air flowing through when both valves are open and bleed off boost. However these guys have some very respectable cars out there (mostly NA though) so i was just seeing if anyone else had tried out this kind of cam.
LS1 Tech Administrator
The Aussies runs lots of cams like that in blower applications. They seem to make stupid power with them.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
just to give you an idea of some of the fastest lt1s and overlap.
I ran 110, Jeff gilberts set up went 9.0 was capable of high 8s for sure had 109, Z8s had 108.5 on his when he had the YSI.
go figure everyone seems to know alot about blower cams
I wouldnt sweat it. FWIW I ran 8.90s with a 115LSA cam and I bet it would run 8.90s with the same cam @ 110LSA. I just dont like the power steering killing the car when I turn the wheels and its idling Lower compression and somewhat small CID and low end tractability wont be ideal but if you are driving the car now then I say leave it in. As far as average power output in the usable RPM range I doubt there would be a huge difference between a few degrees of LSA.
You will have guys argue this on both ends of the LSA spectrum and both will make decent power. Camshafts are cheap and easy to swap, try a few different cams, thats what I do
