High Idle
High Idle
I went to start my car (1998 camaro) and the battery was dead. I give it a jump off of my truck and the motor raced up to 3,000 rpms. I tried tap the gas pedal,check the TB making sure it was not stuck open,but nothing seems to work. Thanks for your help.
"LS1>girlfriend" I did open the hood and pushed the TB forward to make sure that the blade was closed. Then I pushed the TB back to open the rpms went higher,so I figure the TB is working properly.
The battery will not hold a charge (dead battery). I recently removed the PS! and installed a short belt maybe the battery is not being told to recharge. I'll go and get a new battery and drive the car around town.
Thanks for everyones help!!
a high idle can also indicate a vacuum leak. one time i shut off my 5.0 and when i went to crank it, the rpms shot to 3500. i looked under the hood and there was a vacuum distribution block and one was popped off. i plugged it back in and it ran perfect. im guessing the vibration of the motor when it stopped popped it off or something. i ended up replacing it.
