Looking to Increase Compression ????
I have a stock Ls1 with a 232/232 .598 112 LSA and I want to Increase Compresion to stay close to 11:1
I got a set of cometic .045 Head Gaskets and I want to get the heads (241) milled but I don't know how much (.020 or .030) and if I'll need to change the Pushrods to 7.350 or stay with 7.400 ???
Any Help will be Very Apreciated !!!!
Thanks
Thanks
You'll have to measure PTV to make final decision.
I would measure with the Cometics and based on that measurement (intake/exhaust) decide on how much to mill while staying safe.
As for the p-rods you'll need to measure with a adjustable p-rod checker and once you have the measurement at 0 lash you add .070>.080 preload on that if you're running stock lifters (or Comp 850-16 for that matter)
Forget it !!! To much trouble for a little gain... I'll just mill them 0.010 with the 0.045 Cometic Gasket so I'll not have any PTV problems or Pushrods to change... Thanks for your help anyway !!!
