5inch down pipes
5inch down pipes
What are you guys doing with them? Do you just dump them before the k member? I was thinking about running it out the bumper maybe out in front of the front tire. How many of you dump it on the ground before the kmember? Pics would be great thanks
Would you like to come out the back of your car?
Is this going to be a street legal car, if it is i would have it go from a 5" downpipe to a reducer to a 4" pipe right before the K-member and have the 4" pipe all the way back.
on mine (you can see pics in the truck manifold sticky) i was able to squeeze a 4" pipe using the bmr old style tubular k-member with poly motor mounts.
mike brown was able to squeeze a 5" DP through a bmr kmember with a custom solid motor mount. pics also in the truck manifold sticky.
it is a street car but only driven maybe once a week. I am going to do a s95 or two tc76s. I think two 76s would be better for fitting purposes and my intercooler setup. I still might dump the two 3 inch down pipes. I was wondering does it make a mess under the car?
LS1Tech Sponsor
On mine we made it exit right after the k-member but the ground clearance sucks. It is also a racecar so i see absolutly NO street. I will probably have Josh Build me another downpipe after a while.
in this pic you can see how close it is to the ground.
nice i was thinking about something like that. i am waiting to see about the new FI-X series turbos before i do anything. I was thinking about coming out the bumper but dont know if it would melt the side of the car or not.
