hemo me pick the right pushrod. 7.260 at ZERO preload. LS7 lifters.
Old 12-07-2007, 11:47 AM
SatisTraction's Avatar
Question help me pick the right pushrod. 7.260 at ZERO preload. LS7 lifters.
ok, i have been working on a PTV problem and the pushrods are part of the issue. i had 7.4 pushrods with stock rockers and they are too long. the head have been milled .015". i made an adjustable pushrod and it is 7.260" long at zero preoad on the LS7 lifters.
i beleive the ls7's like .080 of preload. that would make the pushrod .080 longer. or 7.340" so would some 7.350's be perfect for me?
Old 12-07-2007, 08:35 PM
LS1HIGHLIFE's Avatar
**** when you find out, let me know how you did all of your measurements. I need a this is how you check for correct push-rod length for dummies.....
Old 12-07-2007, 10:49 PM
RE AND CHERYL's Avatar
If .080" is the right preload then 7.340" would be correct for you.
Re'
Old 12-08-2007, 01:17 AM
PREDATOR-Z's Avatar
if your measurements are correct 7.325
