Need other's experiences:Will this fix the "soft clutch pedal when going WOT"
Old 12-07-2007, 01:41 PM
soontobeLS1's Avatar
Default Need other's experiences:Will this fix the "soft clutch pedal when going WOT"
Well,
I plan on buying the Textralia oz700 (x-grip), new upgraded GM Master cyl and Slave. I will transfer my old braided line which has the drill mod already, or I will just drill the new line.
I will also wrap the line very well with rubber heater hose as well as aircraft heater hose and tuck it away from the headers.
Yes, I have read the sticky 1 million times.
Just want to know if others who have done this that it has worked.
Thx for any opinions.
Old 12-07-2007, 01:45 PM
LivingCanvas's Avatar
Thats going to fix all your clutch woes. Very nice set up you got going in there. The only thing you can screw up is the bleeding of the system, other than that, you new stuff should be trouble free
Quick Reply: Need other's experiences:Will this fix the "soft clutch pedal when going WOT"
