TSP Toquer V.3 ?'s
Old 12-08-2007, 11:04 AM
Lt1Porsche's Avatar
Default TSP Toquer V.3 ?'s
Im getting really close to Head/Cam time and im been searching and studying post after post for a long time and have a few questions about the Torquer V.3. Has anyone used the cam yet? Numbers? Comments? My T/A is an Automatic with a Yank SS 3600 full bolt on. I like the profile of this cam but my main interest of getting a cam is Torque. I want LOADS of TQ and as early as possible. Being an automotic I really dont want to travel above 6400rpms. Any input would be appreciated.
Torquer V.3 231/234 .643"/.598" 111 LSA
Old 12-08-2007, 11:50 AM
ArrestMeRed99Z28's Avatar
do a search in the dyno section, you'll find lots of graphs of that cam
Old 12-08-2007, 12:33 PM
14 Second Truck Club
mzoomora's Avatar
I have that cam in my full weight Z28 with your same converter and 3.90's. It has gone 1.5x 60 fts and 11.56. I am using the Patriot 243's and also have a FAST 90. I think it will go faster without the SLP LT's and if I go true duals. I dont know what the concern with tons of low end is when you have a 3600 converter. This cam made good torque(enough that the tuner made a comment) and drives nice. With your converter you wont have any problems getting into the powerband.
Old 12-08-2007, 12:36 PM
jcolews6's Avatar
TSP advised this cam to me also.
Old 12-08-2007, 08:23 PM
Lt1Porsche's Avatar
Did you have any P to V clearance problems?
Old 12-09-2007, 04:11 PM
jared1993's Avatar
Check out the post I just made
https://ls1tech.com/forums/dynamometer-results-comparisons/827433-i-just-might-have-most-rwhp-cam-only-tsp-torquer-v3-ls1-opinions.html
Old 12-10-2007, 08:19 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
That camshaft should work really well especially with a .040" gasket & a nice set of PRC stage 2.5 heads. You should see about a 100hp gain from those mods!!
http://www.texas-speed.com/shop/item...id=84&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
