Comp Cams XE-R Questions
Old 02-03-2003, 03:37 PM
SSCamaro99_3's Avatar
Default Comp Cams XE-R Questions
Any thoughts on a Comp Cams XE-R 224/224 .567/.567
112 lsa 4 degrees of advance? Will it work well on a stock engine that amy be getting longtubes in the near future? How is the idle? I am not the most knowledgeable about cams: read moron, not quite, but mostly uninformed. Thanks.
Old 02-03-2003, 03:55 PM
98TAauto's Avatar
Default Re: Comp Cams XE-R Questions
whats it going in?? A4 or M6??
for a M6 i'd get the 112, but for a auto i would stick with a 114. I have the comp 224/224 .563 114 and its great in upper rpms. I just havent fixed my warm stalling issues yet. Idle sounds awesome though a open cutout, but with it capped it sounds like stock. You will more than likely have to raise your idle a tad, and do some other tweaks to make your car idle and run better
Old 02-03-2003, 04:09 PM
The Juggernaut's Avatar
If it's an XE-R I think it's a .581 lift.
Old 02-03-2003, 04:19 PM
M-6. I haven't been able to get the sig to work.
I don't run at the track (yet), or push the car past 5500 RPMS very often ( usually doesn't break 5000, no need; ricers). I really am looking for something with a nice kick in the pants. Cam is local so I am invetigating a little (.567 lift is what I am told). Thanks
<small>[ February 03, 2003, 04:22 PM: Message edited by: SSCamaro99_3 ]</small>
Old 02-04-2003, 03:06 PM
muscratmauler's Avatar
there is a misconception out there. XE & XE-R are the same grind, ramp rate also. They are both Xtreme eenergy cams. However the XE is a flat tappit cam and the XE-R is a hydraulic roller cam.
If you got the same specs the two cams would be identical
In a nutshell any "Xtreme energy" cam for us would be an XE-R
hope this helps
Old 02-04-2003, 04:22 PM
gator's 99TA's Avatar
muscrat, are you sure on your numbers there?
and i am almost positive the xe-r lobes start at .581". the .56x lift is the xe lobes. imho they wont make a power difference in a mild build up motor.
is this travis' cam by the way? just wondering.
Old 02-04-2003, 04:59 PM
Thanks for the help, but it has sold. I learned some stuff, so thanks guys. I really need to sit down and do some studying on lift, duration, lsa, and ramp rates. That way I would know what will work well on a basically stock car(for now). Thanks again. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old 02-04-2003, 06:35 PM
LS1derfull's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by muscratmauler:
<strong> there is a misconception out there. XE & XE-R are the same grind, ramp rate also. They are both Xtreme eenergy cams. However the XE is a flat tappit cam and the XE-R is a hydraulic roller cam.
hope this helps </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Im sorry but this info is not right, XE and XER are both roller. XER is more aggressive ramps and requires more spring pressure. I have literature right from Comp. about this.
Old 02-04-2003, 08:48 PM
Fenris Ulf's Avatar
hope this helps </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">FALSE <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
XE and XE-R are both hydraulic roller, like the LS1 is from the factory.
Old 02-05-2003, 06:24 AM
well if you don't believe me call comp yourselves
I've spoken with 3 different people on different occasions that said the exact same thing
By the way, the R in XE-R stands for roller
after you talk to comp let me know what they told you
John
Old 02-05-2003, 08:06 AM
Top Fuel's Avatar
Comp Cams has many categories of lobes. They have High Energy, Dual Energy, Magnum, Hi-Tech Race, Nitrous HP, Xtreme Energy, and so on. Xtreme Energy is then broken down into many types of lobes. You can get Xtreme Energy in both roller and flat tappet. The most common Xtreme Energy lobes for LS1s are LS1 High RPM lobes(design #'s 3705-3719) and LS1 XE-R ramp lobes(design #'s 3720-3734).
later,
Steve
Old 02-05-2003, 10:31 AM
EXACTLY, XE stands for xtreme energy "XE"
xtreme energy roller "XE-R"
here is the number for those who want it
1-800-999-0853
John
Old 02-05-2003, 10:50 AM
Top Fuel's Avatar
I don't see why "R" would stand for roller. You can get Xtreme Energy LS1 High RPM lobes and your still going to get a roller cam. Obviously all LS1 grinds are going to be roller.
Steve
Old 02-05-2003, 11:07 AM
Fenris Ulf's Avatar
<strong> EXACTLY, XE stands for xtreme energy "XE"
1-800-999-0853
John </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Wrong. XE and XE-R are both hydraulic roller lobe profiles, XE-R are faster ramps and subsequently have about 4 degrees less advertised duration at an equivelent .050" duration.
Old 02-05-2003, 11:11 AM
ALRIGHT, instead of getting in a pissing contest, why don't you guys call COMP CAMS yourselves
Old 02-05-2003, 01:05 PM
nothing like talking to a $7/hour rep on the phone <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 02-06-2003, 05:37 AM
So I guess if I tell you my car is a 6-speed, but you say it's auto, you must be right. What the Hell would I know.
Old 02-06-2003, 08:39 AM
CHRISPY's Avatar
You're wrong Muskrat. XE and XE-R are both Comp Hyd roller lobes. I have had BOTH cams in my car.
Chris
Old 02-06-2003, 11:25 AM
i, like many here on the board and in real life, know of many people that have had BOTH cams in their motors. r - probably stands for something like race for the very fast ramp rates.
if the r stood for roller cams and rockers, then stock ls1 motors would have a real problem using them right? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old 02-06-2003, 01:40 PM
Onyx LS1's Avatar
Muscrat, you are wrong. I have had cams with XE lobes, XER lobes, and with XER intake lobes and XE exhuast lobes. They are obviously both roller lobes. The XER is just a more aggresive profile.
Quick Reply: Comp Cams XE-R Questions
