Built 4L60-E Transmission for LS1 $1350
I am not going to use this trans because I am going to use a Transbrake 400. Here are the specs:
New electronics, Hardened pump rings, Servo D ring kit instead of Teflon rings, New Accumulator Pistons, New Valve Body Spacer Plate, Modified Pump Assembly, Oversized Boost Valve, Transgo Hi-Rev Release Springs, High Quality Overhaul Kit, Frictions and Bushings, Transgo Shift kit, Borg Warner dual cage 29 element Input Sprag, Corvette 2nd gear Servo kit, Wide rear sun gear bushing, Heavy duty sun gear shell “The Beast”, High Energy 2-4 Band High Energy 7 friction clutch pack with full thickness Kolene Steels, Teflon Pump Bushing. $1350
