Valvefloat Questions..... CamSwap ?'s
Old 12-08-2007, 08:35 PM
RearMountKing's Avatar
Default Valvefloat Questions..... CamSwap ?'s
Hey fellas...
I just got my STS installed.. .Loving the power..
However, @ about 8psi...@ 4k and above it feels like the engine cant make anymore power...
Is this considered ValveFloat? beacuse I dont have better ValveSprings??
Also, I picked up a set of 918's and 7.4 Hardend PR's.
I figured If I was going to do all of that, I was going to put a cam in as well.
So I had two choices Im stuck Between.....
224-224-588-588-114
224-230-585-595-112
I know that a Lower LSA will cause a loss in boost, but Im not really too concerned about that..!!
Any help is appreciated guys! Thanks so much!
Old 12-08-2007, 08:36 PM
Also.. Is there a need to change the Oil pump? The cars got about 128k on it!!!!
Old 12-08-2007, 09:01 PM
sroach20's Avatar
new oil pump, ls2 timing chain, and make sure the 918s are the new ones. you can get the 224/230 on a 114, its what i have.
Old 12-08-2007, 09:18 PM
What do you mean by the NEW ones... Arent all 918's the same...?
Old 12-08-2007, 09:24 PM
sroach20's Avatar
the old ones had a habit of snapping and dropping a valve. i dont remember the batches so you may want to do a search on it.
Old 12-08-2007, 09:27 PM
Awesome.. Thanks for the info!
Old 12-08-2007, 10:34 PM
02 BLK WS6's Avatar
Oil pump is not completely necessary. While it is a good idea to change it, I opted not to when I did my cam swap and I have 124,000 miles. No problems, with good oil pressure still.
Old 12-08-2007, 10:50 PM
sroach20's Avatar
124,000 miles and no swapping the oil pump. thats like kicking a bull in the ***** and hoping you can outrun him.
Old 12-09-2007, 01:25 PM
Ok, so its a good idea to change it out then! Plus there only like 80 bucks... So why not...
Old 12-09-2007, 03:30 PM
vettenuts's Avatar
FI requires a pretty stout spring, 918's (new or old) may not cut the mustard.
Old 12-09-2007, 04:14 PM
slp--firehawk's Avatar
Valve flotation? I doubt it. Maybe its your turbo size. Yuh know you could always just crank that turbo up a couple pounds and make ur problems dissapear ha, half joking, but no it is an option
Old 12-09-2007, 09:37 PM
Well I have heard that the valves start to float around 8-10 psi... Its diff. for every car.. and I think thats whats going on with mine... Plus Im going the cam swap anyways, so I will see what happens!!!
