How to keep oil from coming out breathers
I'm running speed inc's billet valve covers with a breather on each. I get some oil drops out the breathers that runs down on to my headers. There are no connections on the valve covers for a pcv hookup. Do I have any more options?
Run breathers similar to the pan-e-vac type that plumb to the exhaust on drag cars (closed element with a 1/2" tube coming out of the top, no pics, sorry!) to a catch can with an open element breather on top. I think there was group purchase on this type of set-up on here not too long ago.
https://ls1tech.com/forums/sponsor-group-purchases/734396-group-buy-billet-3-catch-can-check-out.html
are u running these?
cause those dont allow for running a catch can to hold that oil that is dripping
on the stock valve covers there is are nipples
you could probably tap your covers so u can run lines to a catch can.
LOL Mustang parts! There not a sponsor but a cheap *** part like this I dont see a problem with posting a link. I got mine from the local parts store that carries motorcraft. Took my drilled and tapped oil caps,Grinded the inside a little and shoved these bad boys in. They work rather well! Ok thats enuff of my PCV secrets for today.
TT-TECH Veteran
[QUOTE=JMBLOWNWS6;8300035]LOL Mustang parts! There not a sponsor but a cheap *** part like this I dont see a problem with posting a link. I got mine from the local parts store that carries motorcraft. Took my drilled and tapped oil caps,Grinded the inside a little and shoved these bad boys in. They work rather well! Ok thats enuff of my PCV secrets for today.
u
Yeah I've seen people put Steel wool into breathers before for a simular effect. Just didn't like it much.
u
http://www.exoticperformanceplus.com...html?item=1356
We installed this breather on my Z28, hooking it up by way of the valley pan. So far it looks like it is doing the job quite well. Bob
i just bough some of this stuff and cut it up into a small enough piece and shoved it up in there. its cheap enough, so i replace it every month or so but im sure i prolly dont even need to change it that often or at all probably
http://www.petsmart.com/product/inde...ductId=2754076
Those carbon fiber valve covers are bling who sells those, I have factory valve covers with breathers in them on each cover could I weld AN fittings and run hose from each fitting to the moroso catch can.
Heres a pic of mine. I got the breather tank from a gut on here. Im running the Speed Inc. Valve cover too. With PVC grommets in the valve cover holes. Than a -10 fitting (fits nice and tight) with -10 hoses from each valve cover running to the breather tank.
Ron
Ron
