Just another LS1 Procharged Mustang
Hi everyone just wanted to share my latest build.
1993 Mustang,AJE k-member,man-rack,kooks headers,p1sc1 with 8psi,th400 w/brake, 8.8"rear with 4:10's. all that is left is for me to tune it and then get it to the track for some times.Thanks for looking.
Roy.
Roy.
is that an asa motor? you've got fittings down near the bottom, and it looks like you got a carburator manifodl with a sheetmetal plenum on it, which is kinda cool, im just kinda noticing that.
cool setup either way.
Thanks. Its a 2000 trans am motor with a mustang radiator, I just moved the upper hose fitting from the right to the left and the lower from the left to the right on the radiator and used trans am lower and upper hose with no power steering cooler for the top.
I dident have modify any of the brackets they fit right in.and you have to use the f-body air intake fron the kit.. I chose the mustang becouse its 3000lbs with the motor and they just work. and the ls1 becouse its light and you can make good power with just some boltons.
Its running now, I just have to get it on the dyno for some tuning and get it to the alighnment shop. it should be a week or so. I am planing to get that belt tensioner kit for the blower soon.
