FTRA- WTF did I do wrong??
Old 06-25-2003, 03:18 PM
BurnOut's Avatar
Default FTRA- WTF did I do wrong??
A long time ago I bought a FTRA setup, and just now got around to installing it.
I have never in my life bought a product for a specific application that fit so damn poorly.
I had to bend the $#!+ out of the lower plate right below the "wings" so that the bolt hole for the hood latch support would even be in the same neighborhood. Then I had to bend the $#!+ out of the back part of the top flange so that the radiator support could actually sit far enough down for the radiator pads to hold the radiator.
All I can figure is that I must have been doing something WAY wrong, 'cause everyone talks about how easy it is to install... I just hope that it works bettr than it installs...
Old 06-25-2003, 04:24 PM
WILWAXU's Avatar
Default Re: FTRA- WTF did I do wrong??
Certianly sounds like you did something wrong...
Old 06-25-2003, 05:34 PM
SNAXS's Avatar
I think your doing something wrong also, Ive never heard of anybody having trouble wiht a FTRA kit.
Old 06-25-2003, 06:42 PM
Dope's Avatar
Dunno what to tell ya, mine flew by in like 30 mins. I just installed everything loosely until it all fit and then tightened the bolts.
Dope
Old 06-25-2003, 08:09 PM
needmoremoney's Avatar
All I can say is that mine took about 15-20min to install. VERY easy. Something had to have been wrong.
Old 06-25-2003, 08:33 PM
Louis's Avatar
I think its the operator
Old 06-25-2003, 10:31 PM
BurnOut's Avatar
DEFFINITELY an operator issue...
Seriously... I'll bet it took a good hour and a half, and that's with a lift, etc... it just did NOT want to go... however, in the end, I just had more "you're gonna" than it had "don't wanna"...
Old 06-25-2003, 11:30 PM
CamaroSS_2002's Avatar
I had the same problem with mine when I had one. So I don't think it's operator error.
Old 06-26-2003, 01:16 AM
Mike K.'s Avatar
Mine was easy to put in but it was a bitch to line up that bottom plate, I actually took off the top plate and lined up the bottom plate to convince myself that it did indeed fit
Old 06-26-2003, 08:33 AM
2002z28b's Avatar
I to had some problems with fitment. I had to ovalize the bottom mounting holes for the kit to work. All in all the mod was worth the effort. Still no track times yet.
justin
Old 06-26-2003, 05:05 PM
svtkrusher5's Avatar
dog i think you put it in backwards
