How long Stock Clutch last?
Old 12-11-2007, 09:02 PM
pitbull14218's Avatar
Default How long Stock Clutch last?
My car is a 2000 M6 WS6 with 59,000miles on it and i was wondering how long the stock clutch would last. I dont beat on the car at all maybe a couple runs 1-3 gear, I have 4 year loan lol. thanks. I did the test to have it in 5th gear between 30mph-40mph and floor it, it didnt slip. thanks anyway to tell how much longer though? thanks again.
Old 12-11-2007, 10:09 PM
RareBreed0295's Avatar
Mine just tripped over 80k and its still going good if that tells you anything. And im not exactly easy on it either.
Old 12-11-2007, 10:33 PM
corvet786c's Avatar
My clutch fluid was dark and clutch was sticking to the floor alot so I replaced mine around 60,000 miles.
Old 12-11-2007, 10:37 PM
BLK02TA's Avatar
Depends how you use and abuse it. Keep the fluid fresh, I'm sure my disk is fine however I think my slave is going out. Still grabs great at 65k.
Old 12-11-2007, 10:49 PM
Benner's Avatar
I swapped mine out at 114,000. Still grabbed okay. The last 36,000 miles was with around 385 rwhp on it as well.
Old 12-12-2007, 12:08 AM
|2ocky's Avatar
Mine has 64k on it and works fine, but doesn't grab very hard.
Old 12-12-2007, 04:58 AM
bryan04h's Avatar
i have had my clutch for 85k now stock
Old 12-12-2007, 08:18 AM
black01_WS6's Avatar
I fried mine at around 94k. I had 20k with my current mods. I didn'y beat on it too hard as I knew I would explode it on a hard launch. I also has the ls6 clutch in from the factory.
As long as you keep the fluid fresh and don't do a lot of burnouts, and clutch drops it should last a while.
Old 12-12-2007, 08:30 AM
WiseAssJester's Avatar
I am a Magician.
I turned my clutch into little bits of black dust at 58k miles.
One nitrous pull. Mid gear, too. Was pulling, pulling, pulling, zip! Haha
Old 12-12-2007, 09:01 AM
dc8fixer's Avatar
I have 150,600 on my 99. As far as I know its original(I bought the car used). I had to pull the transmission at 140,000 it was grinding between gears. I took pictures of my clutch and posted them(on another forum) wondering if it was original. Nobody replied, so I put the transmission back in after it was overhauled. It still works great!
Old 12-12-2007, 09:13 AM
bryan04h's Avatar
if that was the stock clutch that is insane!!
Old 12-12-2007, 10:13 AM
alamantia's Avatar
no f-body came with the Z06 (LS6) clutch from the factory
Old 12-12-2007, 10:22 AM
01CamaroZ28's Avatar
01s and 02s came with the ls6 clutch stock actually...
Old 12-12-2007, 10:28 AM
alamantia's Avatar
The LS6 clutch is part number 12570806
The clutch that came in the 01's and 02's is part number 12581650
Old 12-12-2007, 10:42 AM
WhosNXT's Avatar
I have allways heard the 01-02 cars were equipped with the ls6 clutch also. Most people on this board would back that up too.
Old 12-12-2007, 11:07 AM
alamantia's Avatar
LS6 hydrolics maybe but the clutch assemblies are two different part numbers
Old 12-12-2007, 11:14 AM
LordOfChaos's Avatar
my factory clutch went bad at 12800 miles. but lets just say i'm a lil abusive...
Old 12-12-2007, 11:58 AM
95 Z28's Avatar
lol damn. I'm at 47k i think and it's holding good still. Grabs hard with the 100 shot but I'll be swapping it out for a RAM this winter.
Old 12-12-2007, 12:55 PM
Jakester136's Avatar
mine was replaced at bout 76K, (not to change the subject) but I was wondering is there a "break in period for clutches"???
Old 12-12-2007, 01:04 PM
chavez885's Avatar
https://ls1tech.com/forums/showpost....80&postcount=2
scroll down to 01-02 changes...number 8 for 01, number 6 for 02
Quick Reply: How long Stock Clutch last?
