Prostars on LT1
Prostars on LT1
I was wondering if anyone has put a set of 15x10 prostars on a LT1 camaro. If so what all did you have to do. Did you have to grind the caliper or not, and what back spacing did you use. I would like them to tuck so that the tire sticks out even with the top of the rear fender all input is great thanks
I'm running a 15x10 prostar in the rear of my 94 lt1 camaro. You will need a 7.5 backspacing. I had to grind down the caliper also. I'm running a 275/50/15 tire and it fits perfect.
