Do turbo blankets work?
Old 12-12-2007, 08:38 PM
ls1408cp's Avatar
Default Do turbo blankets work?
I have been debating on running a turbo blanket but was wondering what the advantages are. I know keeping heat out of the engine bay is one. I also heard someone saying it would spool faster. Has anyone tested one back to back to see a difference in spool time.
Old 12-12-2007, 08:39 PM
LS1TECH Sponsor
DrTurbo's Avatar
Most of the advantage is heat. ALOT less of it under the hood.
Old 12-12-2007, 08:46 PM
TwnTrboCE's Avatar
I have one on my car that I got from Forced Inductions. My exhaust housing is very close to the plastic shroud on my fan. The blanket actually has a cut in it from the fan. There are no signs of heat damage at all. Very pleased...
Old 12-12-2007, 08:47 PM
LS1TECH Sponsor
DrTurbo's Avatar
Mike are you using the T6 blanket? I would imagine so with those big thumpers in your sig....lol
Old 12-12-2007, 08:48 PM
ls1408cp's Avatar
wow thats close. It is going to be tight if i do this 98mm behind the radiator.
Old 12-12-2007, 09:53 PM
Bill Reid's Avatar
I have the T4 blanket from Forced Inductions... love it
Bill
Old 12-12-2007, 10:24 PM
TwnTrboCE's Avatar
Yah it's a T6 The blanket still looks new on the inside. I was suprised when I took it off...Good product.
Old 12-13-2007, 07:16 AM
KraZy's Avatar
How much are your t6 blankets?
Old 12-13-2007, 08:54 AM
LS1Tech Sponsor
hellbents10's Avatar
We got our t4 blanket from FI and it is awesome.
This letter comes from TJ, in Spring Lake, MI
Dear FI, I get so excited every time I make a pull and my under hood temps are still low!!!
Old 12-13-2007, 09:10 AM
PHIL H's Avatar
Anyone know how much difference there is between a coated exh side and using a blanket? My 101 is coated and i have heard that it works very well also. My setup will be very similar to the firebirds setup..
Old 12-13-2007, 10:43 AM
LS1TECH Sponsor
DrTurbo's Avatar
Coating will keep you in the 800-1000 deg range coming off the housing, if its swaintech. A blanket will keep you around 300deg. BIG difference....also ours is not the cheap garbage blankets with the metal mesh liner, so they will stay together for the long haul.
Old 12-13-2007, 10:47 AM
DMH Fabrication's Avatar
PM me a price also. thanks.
Old 12-13-2007, 10:49 AM
Photochop's Avatar
Cool..literally
One more thing to buy for the build!
abbaskhan's Avatar
SOTP spool time a little quicker...... heat underhood ALOT less
Old 12-13-2007, 10:51 AM
LS1TECH Sponsor
DrTurbo's Avatar
Full frame thumper blankets are 239.99
Your can order online through this link if you wish......
http://www.forcedinductions.com/product7.htm
Old 12-13-2007, 12:51 PM
DanZ28's Avatar
Is it the T5 cover for an S91?
Old 12-13-2007, 12:57 PM
LS1TECH Sponsor
DrTurbo's Avatar
Yes it is..
Old 12-13-2007, 01:11 PM
MECHAM's Avatar
Yes it is..
same for a ST80
Old 12-13-2007, 01:20 PM
Reject's Avatar
can we get them with a design? lol jk i'm going to pick one up soon
Old 12-13-2007, 02:02 PM
LS1TECH Sponsor
DrTurbo's Avatar
Originally Posted by MECHAM
same for a ST80
ST80 will work with the T5 and the T4, but the T4 is very tight and will not cover fully, but still works.
Quick Reply: Do turbo blankets work?
