How much does it cost to replace a syncro?
I have a bad feeling that my 5th gear syncro is going out, as it grinds most every time I shift it into 5th, and some times it is VERY particular about going into 5th such as it won't always go into 5th from 6th, or from 3rd, most times only from 4th gear.
Anyways, anyone have this done by a shop, or a dealer before? I just want to get some kind of ball park on how much this is going to cost me.
Most people charge between $300-$450 to pull and reinstall the transmission. The average rebuild labor cost on a transmission is $300-$350 of course dealerships are higher. An average Carbon Blocker ring Kit is $169 to do them all.
Hope it gives you some insite to cost.
Thanks,
Amber
Thanks,
Amber
Oh good God! So, all said and done, an average of $800 or so!!???
Before I get ahead of myself, does it sound like the syncro is my issue here? Very specifically, if I am driving the car hard through the gears, and I try to go into 5th from the top of 4th, a lot of times it won't go in at all. If I try to downshift from 6th to 5th, or even upshift from 3rd to 5th sometimes it won't go in no matter how hard I try. If I am driving the car under regular driving conditions and I shift from 4th to 5th it grinds. However if I pull the shifter out of 4th with the clutch down, and wait a second or two, and then shift it into 5th, it goes in as smooth as butter with no sounds. Does this sound like a syncro? Or do I have other issues at work here?
Thanks,
Amber
Thanks,
Amber
Remember ours are packages. You get billet slider keys, bronze fork pads, steek fork 3/4, new 1/2 slider, new 3/4 slider and what ever else was on the invoice. I try to tell people you don't want to fix just what is wrong if you are going to take it to the track. You always want to upgrade what you can which costs money. Fixing the problem is usually just as expensive as upgrading while you are in there since you are only paying labor once.
Amber
Amber
It just turned over 92,000 miles. I have only owned the car since Feb, and put only about 7,000 miles on it. Like everyone else, I would like to get this fixed as cheeply and easy as possible. What do you figure are the parts I will need? Syncro? Gear? As you put it in an above post, what all would be a good idea to change or upgrade with this many miles while I have the tranny out?
I would do for sure the following:
5/6 Slider- $95
Carbon Blocker Rings- $169
Bearings- $159
Everything else will be at your discretion and what you want to spend the money on. The other things we normally suggest replacing but make the cost go up are:
1/2 Slider- $115
3/4 Slider- $115
Steel 3/4 For- $39
Billet 3/4 Keys- $75
Bronze 1-2 Fork Pads- $30
Bronze 3-4 Fork Pads- $30
Now as far as the gear goes that would be if it is damaged. The gear is $95 and depending on how long it has been since the problem started the gear might be fine. In most cases it is but there are those out there that can't be saved.
Amber
5/6 Slider- $95
Bearings- $159
1/2 Slider- $115
3/4 Slider- $115
Steel 3/4 For- $39
Amber
Amber
Amber
LS1TECH Sponsor
I just fixed a reverse problem in an f-body t56 today. Our labor to pull the transmission from the car is $200. I charged 1 hour labor to remove the tailhousing and repair the reverse components ($68). His total bill with a new slider and blocker labor and all was less than $400.
Well, the biggest cost to me (and pain) will be from labor, or yanking the tranny and paying shipping to wherever it gets repaired. I know of a good transmission shop back where I am from in Indiana, and I may have them give me a quote on labor, and then get all the "possible" problem parts replaced.
Jonathan, what would be the turnaround time in fixing my tranny? Would it be something that could be done in a buisness day? Or are we talking much longer?
I dont know if this would have anything to do with it, but when I changed the ATF in my T56 i refilled it with synthetic fluid, it didnt like that, i was grinding 4th and 5th, i drained it and filled with conventional ATF and it went back to normal. I dont know if you have chamnged the fluid or not but i would try that before pulling the trans, just my $0.02
LS1TECH Sponsor
It could be done in one business day as long as the gear itself isn't damaged. I don't usually stock gears, but even if we had to order anything it shouldn't be longer than 4 days before its back on its way to you. Fixing a problem concearning 5th, 6th, or reverse should only take 1-2 hrs tops if you don't want to make any other upgrades.
5/6 Slider- $95
Bearings- $159
1/2 Slider- $115
3/4 Slider- $115
Steel 3/4 For- $39
Amber
5/6 Slider- $95
Bearings- $159
1/2 Slider- $115
3/4 Slider- $115
Steel 3/4 For- $39
Amber
