Wheels & Tires - Slower time with Radials ?!?!?!?!?!?!
Vette beater
12-13-2007, 12:32 PM
:confused: i recently got a pair of bf goodwrench radials in hopes that i would hook up. as i thought, the tires gripped without spinning, however, the car was slower and the engine acted sluggish coming off the line also i ran about 5mph slower than usual. why is this?
Laffs
12-13-2007, 12:45 PM
You bogged, with the extra grip from the drag tire you need to raise your launch rpm accordingly. Play with the rpm's a bit to find that good point. What spun on street tires maybe no where near the capacity of a good d/r.
I've always been told to launch the stock 10bolt so it has just a bit of slip for sake of holding it together, but perhaps some wiser members will expand or prove me wrong.
Jon5212
12-13-2007, 01:18 PM
Yes hooking hard + 10 bolt usually = grenading it.
fitz98ta
12-13-2007, 03:06 PM
traction can also cause your mph to go down a bit anyway. I agree raise your launch rpm till you get just a little slip on the tires for the 10-bolt sake
