Fueling & Injection - Custom Fuel system (CAD)
Gordon0652
12-13-2007, 09:58 PM
I am looking to do a fuel system for my Trans Am, its going to be FI and i was wondering if this would work.
http://i11.photobucket.com/albums/a192/gordon0652/Fuel1.jpg
Gordon0652
12-14-2007, 06:39 AM
Anyone?
Simple "Yes" or "No" would do.
Looks good, just make sure you know what size lines you want to run. How about a pre-filter before the pump?
Gordon0652
12-14-2007, 07:54 AM
Yes, sorry, i ment to say "Filter and Pump" in that order. And i plan on running -10AN lines.
ChevyChad
12-14-2007, 07:56 AM
Are you going for 1000rwhp? If not, may be a bit overkill...
Gordon0652
12-14-2007, 10:59 AM
Well my plan is 850rwhp, and i have a lot of room to spare. The turbo can produce as much as 1200rwhp and my engine can handle it. 850rwhp is just a starting #.
slowbrakiller
12-14-2007, 12:00 PM
might wanna replace that stump tank :D
Gordon0652
12-14-2007, 12:05 PM
NastyPerformance Sumped Tank can handle it.
No Juice
12-14-2007, 04:23 PM
Looks good to me
Speed Density
12-14-2007, 04:57 PM
Exactly how I run mine, works like a champ.
Gordon0652
12-15-2007, 07:26 AM
Alright, thanks for the help!
KMMG
MIGHTYMOUSE
12-15-2007, 08:21 AM
yes that is the way fuel systems run.
it will do you a lot more help to nail down what all fittings you need to make the connections and a conservative amount of hose
sump>stump
in case you are on a budget it will save you at least a hundred bux to not y the fuel to the rails and y it back together, and do a single crossover instead.
550maro
12-15-2007, 09:12 AM
I would just buy the Nasty Performance fuel system and be done with it.
Gordon0652
12-15-2007, 09:42 AM
sump>stump
You mean something like this?
http://i11.photobucket.com/albums/a192/gordon0652/Fuel2.jpg
LS1MCSS
12-15-2007, 01:59 PM
Thats the way mine is hooked up. You can put a pressure gauge at the regulator.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
