rubbing when turning
I just put a set of 15x10 pro stars on my car. The rear brake calipers have been shaved, but for some reason whenever i make a right hand turn I hear something rubbing. It sounds like it may be the brake caliper rubbing against the wheel, but why would it only do this around a right hand turn. Also it doesnt do it when going very slow around a turn, even a 90 degree one, but on the highway, even a little curve to the right and it will make a noise. Yall think the caliper needs to be shaved more, or thing something else is wrong?
Brandon
Brandon
275/60/15. It may be rubbing the inner fender well. I haven't taken the tire off. I literally just got them on today. Ill have to check for that tom. morning. But it really sounds more like a metal to metal type of noise which is why i was thinking the brake caliper. Also after making a hard right, i heard it rubbing for just a little more after the turn, then it went back to normal with no rubbing at all.
