View Full Version : Window Switch
briangto2004
12-15-2007, 06:04 PM
I just bought a ls1 timing tuner and N20 controller from HSW and when i was reading the instructions it said locate the Crankshaft sensor.
Does ne one no where the Crankshaft sensor is?
PLEASE help
thanks!
90nova
12-15-2007, 08:30 PM
Its at the top rear of the motor behind the intake manifold.
bowtierodder
12-15-2007, 09:11 PM
remove the starter and its right behind/above it.
myfast70
12-15-2007, 10:22 PM
I'm pretty sure you can also connect it to the sensor wire that goes to the PCM. I'm pretty sure that it is pin 12 (dark blue/white wire) on the blue connector. Well at least for a 2001 F-Body. You'll probably want to double check that first though.
briangto2004
12-15-2007, 10:50 PM
I tried behind the manifold and thats not it because there plugs won't fit at all. The manual says that is on the passenger side/ near the exhaust but i didnt see ne thing. thanks guys
does ne one have this switch? or ever installed it on a 2004 GTO?
98noscamaross
12-23-2007, 08:58 PM
What he said.
