Drag Racing Tech - Do You Run Tubes In Your Slicks?
Zero4488
12-17-2007, 09:12 AM
Like the title says...I wanna know how many of you run tubes in tube required tires. Just thought I'd ask cause I've had mixed feed back....
RAGENZ28
12-17-2007, 10:25 AM
It's a personal preference I know people who have gone faster with them and faster without them.
Photochop
12-17-2007, 12:13 PM
I ran them on my old '79 camaro with 28x11.5x15 et streets just because I heard they were more stable at the big end than running without. Also heard they were more stable period with tubes. Never tried them without. BUT I had been looking into the hoosier dot QTP tires and was thinking about running them without tubes...but I may go with the drag radials instead to avoid growing on the big end.
Bitemark46
12-17-2007, 12:46 PM
None here and I have rim screws. -Mark
BMR Suspension
12-17-2007, 01:55 PM
In my experience if it's heavy or if it is stick shifted you are better off running tubes or another option would be a stiff sidewall slick.
sickss228
12-17-2007, 04:53 PM
I run stiff sidewall slicks and tubes. From my experiance having this setup, the car reacts alot faster and "hits" alot harder off the line. The only downside that I have found was that the tubes added more rotational weight.
SScam68
12-17-2007, 05:06 PM
I'm running no tubes on stiff walled slick, stick car
I use tubes in 10.5x28 stiffs and in my 11.5x28 QTPs. I have run with and without them, main reason I use them is there is never any leaks, have to use screws with tubes naturally.
Hrod382
12-17-2007, 05:53 PM
I don't currently but they will next year, basically all because of the fact that my tires are flat after sitting a week... Granted I couldn't tell you how old they are :jest:
Zero4488
12-17-2007, 11:57 PM
So it's completely possible to run M/T ET Drags w/o tubes???
Bitemark46
12-18-2007, 11:53 AM
Yep. All the time. -Mark
jakesz28
12-21-2007, 06:21 PM
Ran mine without tubes. Not for sure what I'm going to do next year but I hate adding air every week.
SSPerformance
12-21-2007, 10:04 PM
pain in the ass when the car sits for a week or so to fill them up everytime easyer to run tubes
NJSPDER
12-24-2007, 01:48 AM
i have used hoosier full slicks, hoosier QTP's, and i know many people who run hoosier radial slicks. no tubes in any of them
mike c.
12-26-2007, 05:28 AM
In the past I ran no tubes in my slicks. I found my tires went flat every few days or so. I switched to tubes,my tires never went flat again and my 60 foots got better.
Matt D
12-26-2007, 08:21 AM
I have never ran tubes. I run the 26x8.5x15 MT ET Drags. Time are in the sig.
stressfulcar
12-26-2007, 09:54 AM
I run tubes in mine,29.5x10.5 et drags. No leaks.:nod:
b00sted
12-28-2007, 01:57 PM
http://i18.photobucket.com/albums/b103/xxbulaxx/burnout2.jpg
:D No tubes here.
XX11SECZXX
12-28-2007, 07:51 PM
ran my last to sets of et streets without tubes. never leaked air and never had problems. i think they recommend tubes if you want to run low pressures. never had tubes dont no what the difference would be.
xpndbl3
03-22-2008, 01:22 AM
i just smear liquid dish soap all over on the inside of the slicks two times then mount them and rarely do I add air to them, in fact the car has sat on jackstands all winter and only lost 2 psi. Do the sidewalls and the tread surface on the inside, 2 slicks uses almost a full bottle of dish soap but stops the leaks once mounted and aired up.
Dave J
03-22-2008, 09:43 AM
I just run the tubes less work for me
ssean92
03-23-2008, 08:06 AM
I tried to use tubes but both of them leaked so I had to return them
94nitrousedLT1
03-24-2008, 07:36 PM
Last year I got so tired of adding air during the week and didn't like the car sitting on flats so it will be tubes from now on.
xpndbl3
03-24-2008, 08:08 PM
guess no one is willing to do the soap trick instead of tubes...
Villain281H
03-24-2008, 09:17 PM
M/T since I started racing with slicks in 1994 and never had tubes. As mentioned if you soap/install the slicks/tires correctly sometimes there's no need for screws and/or tubes. Will Stevenson's drag radial Camaro has gone 7.51 at 191 mph without screws or tubes on the radials. I've seen quite a few 1.3X 60 foot cars without tubes or screws, so it can be done.
Derek
7420NW7TH
03-25-2008, 09:13 AM
nope, never had tubes
ssean92
03-25-2008, 03:23 PM
how does the soap help with leaks and other stuff?
Rock_Daddy
03-26-2008, 04:52 PM
I thought slicks were porus and leaking from the rims wasnt the issues. Sitting on jackstands would take alot of pressure off the tires and I assumes they would leak slower.
Camaro396
03-26-2008, 05:02 PM
No tubes here. I run 325/50/15 MT radials and 26x11.5 ET streets. Both without tubes.
Ed Wright
06-20-2008, 02:53 PM
Mine goes low 1.30 60's on Hoosier radials with no tubes or screws.
csjta2
06-22-2008, 09:39 AM
No tubes, Hoosier 29X10 with rim screws
Did the dishwashing soap on the inside, they can sit for weeks and not loose any air
b.lee
06-23-2008, 09:08 AM
No tubes here.
M/T Sportsman Pros.
I never ran tubes. Dish soap or tire slime works pretty good. I drive slicks on the street a lot and they're usually easier to plug when they get a puncture in the tread if they don't have tubes. Just my preference. I also hate drilling my wheels for screws. No tubes, no screws.
PewterZ28
07-01-2008, 11:30 PM
So you guys are saying the tire will not spin on the rim? I thought all tires were mounted with the help of some dish soap? What has changed since I last had a set of tires mounted? Please explain this dish soap method you speak of. :secret2:
Ed Wright
07-02-2008, 09:34 AM
I think they are refering to coating the inside of the tires with dish soap to prevent leaks. I've not had to do anything to my Hoosiers. Guess I have been lucky to have no leaking tires so far, until they are about a year old. I have one set of 10.5 X 29" bias ply Hoosiers on their third season. I still use them on tracks too slick for radials. They still hook great, but will loose about 1 lb a day now. The radials are faster & quicker, so I run them when I can. Have only had to go to the bias tires twice so far this year. I mount mine with just straight water. I feel like it helps prevent slipping on the wheels, I could be wrong. No tubes or screws here. I'm not exactly sure how they do the dish soap thing. Never tried it.
Dragman
08-01-2008, 12:22 AM
Been doing this for about 20 yrs and it works!
Dave J
08-01-2008, 12:41 AM
I filled my slicks with tubes to 13psi in April and they sit at 13.5 psi as of right now(I guess the heat made the psi rise) but all I am trying to say is they dont leak nothing and if you fill with nitrogen the heat wont even change the psi ;)
