Subframe connectors..... worth the money?
Old 12-17-2007, 02:49 PM
Mike96z's Avatar
Default Subframe connectors..... worth the money?
My car is street and strip so handling is important, are subframes needed or are they just an accessory? Is it worth the money?
Reduce chassis flex to a minimum and increase your handling capabilities with a set of BMR subframe connectors. These weld-in subframe connectors fit 1993-2002 F-bodies and will work with all aftermarket exhaust systems. All mounting plates are made from either 3/16" or 1/4" laser cut plates for the ultimate in strength. Boxed connectors use 2" square tubing while tubular connectors use 1-5/8" roll cage tubing. Available in Black Hammertone or red powdercoat.
Old 12-17-2007, 03:04 PM
Donohue96M6Z28's Avatar
I think they're good to have. You're looking for an STB too, right? Thats something I wouldnt waste my money on.
Old 12-17-2007, 03:20 PM
Mike96z's Avatar
not worried about the STB
Old 12-17-2007, 03:26 PM
LS1Tech Co-Founder
Nine Ball's Avatar
I'd definitely recommend them on a flimsy f-body, especially if you have t-tops. Get the weld-in type though.
Old 12-17-2007, 03:28 PM
Mike96z's Avatar
yea, got me a brand new bmr set (boxed) for $90, just wanna know if they are worth keeping. all input is appreciated.
Old 12-17-2007, 04:08 PM
khaos288's Avatar
definitely, they changed the wholllle feel of my car, and alot of traction problems
Old 12-17-2007, 04:09 PM
Splitz's Avatar
SFC fixed my wheel hop!
Old 12-17-2007, 04:11 PM
Mike96z's Avatar
i have alot of suspension done already, just wanna complete it.
Old 12-17-2007, 05:20 PM
Jip99z's Avatar
That is one of the most important items for drag racing, unless of course you like twisting and cracking your chassis! LOL Put them on, you will notice a difference in handling for the better as well, plus a great piece of mind!
Old 12-18-2007, 08:21 AM
Mike96z's Avatar
thanks.... picked them up
Old 12-18-2007, 08:48 AM
Demon Of Dreams's Avatar
i went with the UMI 3 points ... couldn't be happier really
Old 12-18-2007, 09:00 AM
E V I L's Avatar
Any local Houston shops that could install them?
Read the horror story on installuniversity, do not want that to happen to me!
Old 12-18-2007, 09:14 AM
1970judge's Avatar
One of the best chassis mods you can do. F-body flex real easy, just ask my buddy who cant put his t-top on right
Old 12-18-2007, 09:20 AM
Mike96z's Avatar
yea i tried to explain that to someone on the other boards but he swore up and down that the f-body was a redesigned subframe car that didnt flex alot. Just ignored him.
Old 12-18-2007, 09:21 AM
Mike96z's Avatar
on installing subframes? linK?
Old 12-18-2007, 11:52 AM
will350wax's Avatar
link.
Old 12-18-2007, 11:58 AM
00'BlueSS's Avatar
Talk to Josh at LMR
Old 12-18-2007, 12:54 PM
E V I L's Avatar
It's under install documents and subframe connectors tab.
What is LMR?
Old 12-18-2007, 01:27 PM
RYNO_Z's Avatar
Late Model Racecraft.
They are a sponsor here...links in the post above yours.
Old 12-18-2007, 06:21 PM
I'll suggest Bryan Pavlock...
as for the subframe connectors being welded with all 4 wheels on the floor... mine wasn't done this way and I've yet to have a problem with them... I was and still am satisfied after over a year with them on...
for a 2 point, it might make more of a difference... but for the 3 point that I have, it seemed to matter a bit less, because it was supporting more from the center and lca brackets first...
