Bleeding the slave
Old 12-18-2007, 07:53 AM
67pete's Avatar
Default Bleeding the slave
How do you bleed the slave in the car without making a mess?
Old 12-18-2007, 08:13 AM
Sully's Avatar
My best guess would be to install a remote bleeder. That's the only thing I can think of that will keep from making a mess.
Old 12-18-2007, 08:17 AM
67pete's Avatar
a remote bleeder?
Old 12-18-2007, 11:22 AM
pro2low's Avatar
i bought one from a member on here! i cannot remember his name however. it was like 80 bucks shipped and i have it running ou the side of the bellhousing up behind the motor along and strapped it to my fuel rail. it has saved so much time so many times!
ill try and find the paper that cam with it maybe it will have his name on it.
Old 12-18-2007, 01:33 PM
MrEddie's Avatar
This is the link to the sponsor that sells them here....
https://ls1tech.com/forums/showthrea...bleeder+clutch
You have to drop the tranny though, or at least move it back far enough to unscrew the stock bleeder screw and screw in the remote bleeder... good luck
Quick Reply: Bleeding the slave
