not enough room!!
I don't know what you consider modding your car. All I had to do was a little massaging of the inner fender well with a hammer to fit my 315's. They were 11.5" tread width across. My new 305's are 12" tread width and with a little more massaging they fit ok. I just went back and painted the inner fender well.
Are you still running the stock wheels?
on the street i run stock 245/50/16s on the strip i run 275/45/17 bfg drag radials. my car is not lowered, it doesnt have aftermarket axels suspension etc. however with the 275's i have to use 5/16 inch spacers. otherwise the bumpstops get in the way
what wheels are you running on these tires? Do you know the offset? also, to get the wheels/tires on without a spacer. Just jack the car up from the differential. the bumpstop wont be in the way anymore.
