P1SC to D1SC swap ?s
Is the intake hat from a P1SC head unit able to fit onto a D1SC if it has been unmodified? Im doing this swap on an 02 Camaro and the intake hat flange isnt long enough to properly clamp onto the head unit anymore. The discharge of the compressor is what is preventing this..
The compressor housing needs to be rotated. You can do this by loosening the 1/4" allen bolts on the perimeter of the housing and rotating to the proper location. The outlet should be pointing towards 7 o'clock
The same housing is used on the P and D series of blowers, so all you have to do is reclock the blower to where it is in the same position that your P blower was at, or close to it.
I have pic's here that may help you out.
http://www.exoticperformanceplus.com...Car.php?car=12 Bob
