Quick Question About Autometer Engine Temp Guage
So i have a 5.3l LSX base engine installed in a s10 pickup. The stock guage for engien temp doesn't work so can i 'T' off the factory engine temp sensor to the new guage? Or is there a place that i should instal the autometer temp sensor?
The factory engine temp sensor will not work with an aftermarket gauge. It's dosen't even go to a gauge in an OEM set-up. It goes to the PCM which drives the gauge through a serial connection to the cluster. There is an aditional place to install a sensor toward the back of the passenger side head but the threads are metric and incompatible with aftermarket sensors.
Re'
Re'
There is also a large freeze plug in the block that you can unscrew and put it there. I have had mine in both places and it reads the same either way. The plug is right under the headers/manifolds on the block. A company called Equus makes the adaptor you are looking for to go into the head. Be careful because the way it is machined makes it very easy to break if you overtighten it.
I already ordered and recieved my m12 by 1.5 adapter... the problem is that the hole is not big enough to fit the sender in the adapter fitting. What is the part number of the metric sender?
