Accessory drive (yet again...)
Old 12-19-2007, 11:21 AM
JZHeyde's Avatar
Default Accessory drive (yet again...)
Good morning,
I have searched, searched, and searched again. I am looking for an accessory drive for my iron 408 LSX motor. It is swapped into a 63 nova and I want to run something very clean. Right now my alternator is mounted on the drivers side down low and I want to keep it that way. What I am looking to do is this:
1) I only want to run an alternator, no other accessories.
2) Run an electric water pump.
Is it possible to have a belt go directly from the crank to the alternator? Would I need to fab my own brackets?
What other solutions do I have? I found the car shop kit but it looks plain jane for the $500 they want. Does anyone have any suppestions?
Thanks!
Jamin
Old 12-19-2007, 03:44 PM
Buckndol's Avatar
You should be able to make your own brackets pretty easily. You will just need a belt tensioner like the AC has.
Old 12-20-2007, 07:32 AM
'JustDreamin''s Avatar
Or make the bracket adjustable, so that you can tension the belt.
If you run a belt tensioner it should be on the slack side (which would be about where the waterpump is) so that makes it a bit more complicated.
'JustDreamin'
Old 12-20-2007, 07:56 AM
Stovebolter's Avatar
Default Steel Brackets for LS1
I found this recently in an article Super Chevy did. Thier site isnt up so you would have to call. Looks like they have both the A/C and the Alternator high mounts.
http://www.superchevy.com/technical/...de/index1.html
I think this link is the same place though.
http://www.newmancarcreations.com/en...ans/index.html
David
Old 12-20-2007, 03:48 PM
JZHeyde's Avatar
Does anyone know if you can even get a belt that short? Say if I went around the crank and then directly to a low mount alternator?
I appreciate everyones ideas, I will look into them tonight. I have no problem fabing an adjustable bracket.... I might go that route when the motor gets back from the shop. I dont mind buying a kit but I dont really need any accessories, and with the elect. water pump it would look CLEAN with the belt around the crank and alt. only.
Keep the ideas coming and I will let you know what progress I make. Thanks!!!
Jamin
Old 12-20-2007, 03:54 PM
camrs73's Avatar
moroso makes a few things that might be able to give you an idea to go off of
http://moroso.com/catalog/categorydi...?CatCode=30001
Old 12-20-2007, 06:14 PM
72Elkytpi's Avatar
Here is what you need to mount the alternator only with adjustment.
http://www.thunderracing.com/catalog...&vid=3&pcid=14
Old 12-20-2007, 07:39 PM
nova65ss's Avatar
Have you tried this w/o an electric water pump?
Old 12-21-2007, 07:08 AM
JZHeyde's Avatar
That is exactly what I am looking for. They even give belt lengths on the instructions. This was perfect, you actually made my day! I appreciate all of the help. Now I just need to bite the bullet and order that elect. water pump! Thank you for the help. I will post up pictures once I get everything together. Thanks again and merry Christmas.
-Jamin
Quick Reply: Accessory drive (yet again...)
