Got new injectors, need flow test pressure?
I just got a set of 42# SVO green top injectors. My tuner will have to make a new fuel map for them and mentioned that they may be flowed at 32psi instead of the normal 42psi to arrive at the 42# rating. Does anyone know anything about this or know for sure what psi they are flowed at? Thanks
Cajun
Cajun
You need to find out exactly what they flow. You have two choices...(1) send them off to be cleaned and flow matched which costs about $10/injector. This will give you an exact flow rating. (2) Contact the manufacturer and ask them what the flow rating is and at what PSI they are rated. That will get you close enough for fine tuning.
Don't take a guess on this kind of thing...you need to get it right.
I was under the impression that the SVO injectors were rated at 34psi because the that was the pressure that all the Ford FI systems operated at on the pre-mod motors.
My friend had a 5.0 and the fuel pressure was set around 32-35psi.
Re'
Re'
Why not just get the part # off the injectors and then find out what they're rated at. Most of the SVO stuff is Bosch. I see their "42" lb green top injectors are flowing 45 lb/hr at 3 bar so they should still be around 49-50 lb at 4 bar. There are a lot injectors out there so getting the number off them is the safest bet.
OWN3D BY MY PROF!
here's two flowsheets so you can stop arguing
http://redhardsupra.blogspot.com/200...vo-42s-is.html
