Can I mill my heads with this cam?
My cam is a 227/227 .599/.599 on a 110 LSA. Can I mill my heads .030" safely without worrying about piston to valve issues? How much power does this usually pick up and what is the normal cost of it?
Re: Can I mill my heads with this cam?
it looks pretty fun....should really lump....
With my 228/236 571.602 111LSA cam, and my first set of SII 5.7 heads milled .30, When I clayed it, the valves clearly hit th piston. Switched to 5.3 heads milled .005, I had .85 clearance. So if I was you, CLAY IT!!
