MTI SII LS6 Heads questions.
I have a set of MTI Stage II LS6 heads on order. Wayne @ MTI told me that they mill the heads .030. Now, I've read that LS6 heads have a 10.5 to 1 C/R. I have also read that milling .030 should yield about .5 increase in C/R, giving me 11 to 1 compression. Will I have any issues with pump gas? MTI also sold me a set of head shims. Wayne said that they use them on their engine builds. Will these shims negate the increase in compression that the milling creats? Are the shims reliable? If I don't use the shims, will I have issues with stock length pushrods? FYI, I am using a TR224 112 cam with these heads. Thanks in advance for your thoughts!!
LS1 Tech rules!!
LS1 Tech rules!!
Badass pool player
Re: MTI SII LS6 Heads questions.
Can't comment on the pushrod or shim issue, but can tell you from personal experience that MTI Stg II LS6 Heads making 11 or 11.1 are fine on 93 octane pump gas.
I put almost 15,000 miles on my set before I parted the car out and it was a daily driver.
Good luck with your project!
The shims are for your rocker arms and do not effect compression. Aside from the high price you shouldn't have any problems.
[quote
The shims will help but what you really need is some Vaseline..
[/quote]
Hehehehehe! If my wife knew what I paid...I'd be divorced!
I'm such a dumbass...I actually thought that they'd shim the entire head...duh!! I'm still learning this internal engine stuff! The shim on the rocker arm makes sense...the Yella Terras are supposed to come with shims, so I guess I'll have an extra set! Thanks!
[/quote]
LS1 Tech rules!!
LS1 Tech rules!!
LS1 Tech rules!!
LS1 Tech rules!!
1 Post
Lawman, you should be fine with the LS6 heads and TR224 cam, my old set up included MTI stage 2 5.3 heads with a 224 cam and it made great power and torque 434 rwhp and 405 tq - I ran 120 mph thru the traps with a race weight of 3,510 lbs.
I hope so! I'm just starting to understand this head/cam/tuning stuff, but have much MUCH more to learn! The folks at MTI and Thunder Racing both said that I should be in the 430rwhp-450rwhp range with this setup, the bolt-ons I already have, and tuning. Yea or nea?
I called Thunder Racing about camshaft selection. I told them about the heads I was using and that they were going to be milled .030. The gentleman I spoke to said that the TR224 was the biggest cam I could go with because of the milling...I didn't question him.
Leo is right, you WILL make power for sure, but you may not make the most you could using the LS6 heads is all... MTI usually seems to go with their X1 cam (230/227) with the LS6 heads. The heads just don't seem to really start to show their value over regular 5.3 or 5.7 stage II heads until you start to go a little bigger with the cam. The only reason I brought it up is that I'd hate to see you pay the premium price for the LS6 heads and not get the full benefit out of them is all. Obviously this is all JMO, and others will disagree with me.... If it was me and all I was going to do was run a TR224 cam, I'd probably just go with a set of $1400 or so Patriot stage II
5.3/5.7 heads...
I love my MTI S2 heads, but I went with the X1 cam and love it. You can see in sig what I pushed with A4 safely tuned. The 12-bolt, gears and stall eat some rwhp. Poolfanatic pushed 445rwhp and I believe 414rwtq with a 6sp, the same set-up as mine! The X1 is sweet! Good Luck!
Thanks for your thoughts, as I said, I'm still learning, so every little bit of knowledge helps!!
Wayne at MTI talked to me about the X1. He said he's running this combo in his car with 443rwhp...just decided to go with the TR224. I liked what Thunder said and went with their cam...I don't want to touch the short block at this time, so flycutting is out of the question for this stage of my modifications. Also, I liked the fact that the power band for the TR224 starts at 1700rpm seems "street-worthy"
<--wife when she sees the MTI receipt!!
In any case Lawman, you can go larger later with the cam which I have a feeling you will.....
