ASAP: Which Wire is the Signal Wire for the Oxy Sensors?
Old 06-27-2003, 04:24 PM
Ferocity02's Avatar
Default ASAP: Which Wire is the Signal Wire for the Oxy Sensors?
Just need a quick answer. I'm installing an A/F ratio gauge and need to know which color wire is the signal wire without starting the car. There are four wires, it the signal wire the violet one? Thanks a hoot!
Old 06-27-2003, 04:30 PM
Smoke_Ford's Avatar
Default Re: ASAP: Which Wire is the Signal Wire for the Oxy Sensors?
No, the violet is the heater for the )2, the red is power and the black is ground. Leave only one left.
Old 06-27-2003, 06:51 PM
Ferocity02's Avatar
.....okay. Well there arent any red or black wires
There is one violet, one beige(off white), and two light brown ones. This couldn't be more difficult
Anyone know for sure which one it is?
Old 06-28-2003, 12:35 AM
Ferocity02's Avatar
Well I guess GM ran out of good wire so the used light brown for the ground and power wires
From the sensor to the connector those are th colors, but after the connector, the colors are right; red, black, off white, and violet. I spliced into the off white wire hoping this is the signal wire
Old 06-28-2003, 01:02 AM
Smoke_Ford's Avatar
The two wires of the same color are the O2 heaters. I think it is the purple wire.
Old 06-28-2003, 01:16 AM
Ferocity02's Avatar
OMFG! It's the purple wire now, son of a bitch
Old 06-28-2003, 08:51 PM
Ferocity02's Avatar
Anyone know?!?!?!
I think I might of gotten it wrong. When the sender is disconnected from the A/F ratio, there is one green dot at the fully clockwise position, when i hook up the sensor, the Green light goes away and I can just barely see a red light at the fully lean position, after 10 seconds or so it dissapears and the gauge is blank.
Does this sound like I got the wrong wire?
