General LSX Automobile Discussion - gap on ngk tr55IX iradium plugs
ae13291
12-21-2007, 03:17 PM
hey guys i have been searching on the forum for a gap on the tr55's but there seems to be alot of confusion with the regular tr55 and the iradium tr55! the regular ones are .055 gap and i hear people saying .044 for the iradium plugs! these plugs are going in saterday, so i just want to make sure i do the right gap! thanks
sroach20
12-21-2007, 04:13 PM
do not touch the iridiums, they are preset and may be damaged if you touch them. it should be around .040 to .045. do not gap them!!!!!!
ae13291
12-21-2007, 04:49 PM
ahhh fuck!! are you sure, i jus gapped my moms altima's plugs and put them in!! are you sure bout the gapping part!! because i know iradium is lik 10 times stronger then platinum so im sure it wont get damaged!!
sreve
12-21-2007, 05:24 PM
^^^yep what he said:nod:
sroach20
12-21-2007, 05:32 PM
im positive.
ae13291
12-21-2007, 05:57 PM
wow, fuck let me email ngk and let me c wat they say if i had already gapped the ones on my moms car!
ae13291
12-21-2007, 06:37 PM
ok i copied and pasted this from ngk's website about gapping iradium plugs
The manufacturers say NO.
This is because most people do not know how to properly gap a spark plug, and the center electrodes on the ultra-fine iridium can easily snap if mishandled. There is no warranty for snapped center electrodes. The manufacturers say an iridium spark plug will run so much better than a traditional plug, even if it is not gapped for that motor, that they would prefer you just leave it rather than risk snapping the center electrode.
Personally, we at sparkplugs.com, gap our iridium plugs for our own vehicles (we’re rebels). If you insist on gapping your iridium plug, please refer to Proper Gapping for instruction.
ae13291
12-21-2007, 06:41 PM
i want to gap my plugs!! so now its down to .044, .059 and .055 and the factory .060
so im not sure, please let me know guys thanks
ae13291
12-21-2007, 09:09 PM
ttt.... help pleeez
ae13291
12-21-2007, 10:03 PM
i hope i will be able to give ngk a call tomarrow
LS1>girlfriend
12-21-2007, 10:09 PM
i would gap them at .055 if i couldnt wait for the proper gap info from the manufacturer :D
sroach20
12-22-2007, 06:52 AM
this is from ac delco, it covers the iridium which is why they have a smaller gap. the ac and ngk iridiums are the same.
ACDelco Iridium Spark Plugs are the latest evolution in high-performance plugs. The natural properties of iridium, with a melting point approximately 700 degrees Celsius higher than platinum, helps enable the plug to burn fuel more efficiently and to deliver better performance. As a result, the iridium plugs have a minimum service life of 100,000 miles.*
Since iridium is one of the densest materials found on earth, the iridium-tipped center electrode is 50 percent the size of a platinum electrode and 20 percent the size of a conventional nickel electrode.
The secondary microdischarge of the center electrode burns off carbon deposits as they form for superior antifouling performance that, along with the tapered cut-ground electrode, offers enhanced flame spread during combustion.
The specially designed electrodes increase the electric field strength at the gap, reducing the voltage required for sparking to begin, for improved cold starting and quicker acceleration.
The application coverage of ACDelco Iridium Spark Plugs continues to grow, with the plugs backed by a 100,000-mile limited warranty.
*Service life varies with individual driving conditions.
ae13291
12-22-2007, 12:54 PM
ok thanks for the info, but i guess im going to gap them at .055 right now! i wish i could make sure tho, im going to call ngk right now so i can make sure tho, and will it mak performance diffeance from .044 to .055 ? thanks
RedRocketZ28
12-22-2007, 01:10 PM
I gapped my NGK TR55's at .045. Car runs great.
ae13291
12-22-2007, 01:13 PM
redrocket were those the iraduim ones or regular???? thanks
ae13291
12-22-2007, 01:20 PM
man i jus checked my gap and there lik .058 i guess im gonna leave them the way it is!
ae13291
12-22-2007, 07:11 PM
wow i should probly tak a pic of how bad my hands look just from only doing the passenger side
RedRocketZ28
12-22-2007, 10:48 PM
They were the regular ones.
johnh
12-23-2007, 09:04 AM
You can gap them, I have gapped them before...BUT as stated if you put any pressure on the Electrode it will break and you need a new plug. I would just leave them as gapped as they come...no real reason to change it unless you've got a wild setup.
