Drag Racing Tech - "LSX" Lightweight Motor Mount Bushing Stands
MosesMcgregor
12-22-2007, 09:45 PM
Anyone had experience with these? Drop about 5lbs and are a direct replacment...
http://www.spohn1.com/prodimages/1084/103.jpg
RAGENZ28
12-22-2007, 10:28 PM
I would only use those if you plan to run poly bushings, if you're going to a solid motor mount I would just run the one piece solid mounts.
MosesMcgregor
12-22-2007, 10:43 PM
Runnin' poly bushings already but dont want to go all out with the solid mounts.
RAGENZ28
12-22-2007, 10:53 PM
Personally I think it is expensive for 5 pounds.
What's the reason you don't want to run a solid front mount?
MosesMcgregor
12-22-2007, 11:32 PM
lope on the cam shakes the car enough with the poly's. If it wasnt a DD i'd do it. i was mostly curious since i couldnt find anything after a search, wondered if there was a reason for it (problem) but it could be because of the cost vs. benefit.
RAGENZ28
12-23-2007, 09:23 PM
I'd just run the solids, the motor will move less and as far as the chassis it will react better with solid mounts, make sure to use a poly trans mount if you go this route.
I drove with solid motor mounts for rears and had no issues.
Mr.MartyStone
12-24-2007, 08:59 AM
I switched from poly to solids years ago and am purely bummed that I can't run solids with my Profab k-member that I'm swapping to. I really enjoyed the spohn solids while they were on my car, makes you feel much more connected.
And I ran a high 230's duration cam w/ TD's so I know all about cam shake. Trust me on the solids, just bite the bullet. Plus you'll drop about 10 lbs.
Marty
MIGHTYMOUSE
12-24-2007, 01:36 PM
put some christmas money on top of your budget and do an entire k member w/ mounts and you're better off all around in the long run
x2 be well worth the extra money.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
