Loud belt sound in engine bay
Old 12-22-2007, 11:19 PM
98camaro1le's Avatar
Default Loud belt sound in engine bay
The last few days when my car has been idling, my belts have been whining more than usual. When I sit at stoplights its loud enough for me to hear in the car. Usually they are loud for a few seconds on initial start up but then quite down but not for the last few days. Could it just be the cold weather or does my car have a problem i should get checked. Fan belt looks to be in good condition.
Old 12-22-2007, 11:32 PM
2002t/a06's Avatar
does it sound like a bird chirp?
Old 12-23-2007, 12:05 AM
fccs's Avatar
hey yea mine does that to. Its started recently like back in October before I put my car away for the winter and if I start it up it'll still do it and whine like a **** for a good 5-10min once it warms up it seems to go away but ive always wondered whats up with that is the belt going bad or something?
Old 12-23-2007, 12:16 AM
LS1>girlfriend's Avatar
yep, the belt is going.
Old 12-23-2007, 12:40 AM
lsheaven's Avatar
when u say fan belt, are you referring to the serpentine belt?? our cars have electric fans = no fan belts
Old 12-23-2007, 01:01 AM
CJDZ24_Z28's Avatar
If you say whine my current Formula had that while and it was the idler pulley. A way to test and see if its the belt or a pulley would be to get some belt dressing or any kind of lubricant and spray it on the belts while the car is running. If it goes away or goes down in sound its the belt. It not its one of the pulleys prob the idler. If it turns out to the belt get a goodyear gatorback belt. My Vette has just started to do it and a few of my previous LSX cars have done this as well.
Old 12-23-2007, 02:04 AM
fccs's Avatar
So for me.. the belt is probably going? I have like 84k miles on the car now is that around the time they usually go? And if so im guessing a belt is alot of money for these cars? lol
Old 12-23-2007, 02:30 AM
slowjoe99's Avatar
My car has the same problem but the belt only has about 3k miles on it. the belt i had could be old though...
Old 12-23-2007, 08:17 AM
8a8mfh's Avatar
I had my car in for work back when it was under warranty, they put a new belt on it and I swear a handful of silicone grease, a lot of grease. It never made noises before.
Now it just started again but probably because I washed the engine, it sounds like a bird chirping. You can check easy enough, just spray something on it, WD40, water anything and see if it stops. This will eliminate any pulley problems. My belt has about 25,000 miles on it, no cracks, not dry rotted. Either got to change it or spray it.
Old 12-23-2007, 10:34 AM
pitbull14218's Avatar
Mine does it too and i think its embarrising(spelling) I deffinitly will try to fix it some how this spring. One time it stopped after i went through 1st-3rd gear just for fun, then i noticed it stopped, but if i go to start it up so someone can listen to my car and it makes that noise i would probly feel crappy.
Old 12-23-2007, 11:02 AM
bryan04h's Avatar
i had the same problem but i swapped out my serpentine belts and that annoying beater whine went away
Old 12-23-2007, 11:19 AM
mine deffinitly was the bird chirp. so thats supposed to be the belt tensioner?
Old 12-23-2007, 11:21 AM
b4c346's Avatar
just changed both of my belts. $62.00 at napa.squeaking stopped right away.
Old 12-23-2007, 11:30 AM
2002t/a06's Avatar
im not sure man. mine has been doin it and its really startin to irritate me!
Old 12-23-2007, 11:32 AM
fccs's Avatar
You know what... come to think of it this didnt start till sept which was around when I started power washing the engine bay...maybe it just needs some wd40 on the belt or something? And when it would chirp like that id just say to my friends it has a supercharger hahahaha
Old 12-23-2007, 11:38 AM
EastTnZ28's Avatar
If it aint you belts try this.http://www.katechengines.com/street_...etail.php?id=1
Old 12-23-2007, 11:41 AM
bryan04h's Avatar
if it isn't the high pitch whine that last a while then it could possibly be a belt tensioner..but you should def do what CJDZ24_Z28 to find out what it could be...
fccs's Avatar
Mine doesn't feel like it wants to jump off lol it just chirps.. and if I start the car and leave it outside for a good 10min it just goes away when I come back.
Old 12-23-2007, 11:55 AM
Mine is put away for now(winter sucks) but i am deffinitly not having my car chirp around the ladies! What kind of ***** magnet would it be then huh?
Old 12-23-2007, 12:06 PM
fccs's Avatar
Mines away to for winter, holdon I put a video up on youtube that I took just now. To give everyone a idea for me and others who are having this annoying noise.
