04 gto flacid clutch
so this problem started a little over a month ago when my clutch just felt like there was no pressure and it wouldnt go into gear when the car was running.. i took it into the dealer and i told them i thought it might be the slave. they said ya its the slave its leaking $750 i then said F that i can do it myself. the only problem is its -10 out and my garage is full of **** they told me they just put fluid in it because of the leak.. well now the problem started again. but my clutch fluid level is at max! what is an easy way to temp fix this problem? it lasted me a month and a half after they did whatever from the dealer. they didn't tell me if they did a bleed/flush or anything it doesnt even say on the receipt. what do you think guys? thanks a lot!
