my car 427 RWHP what cluth i need?
Old 12-24-2007, 04:59 AM
PONTIAC SLP's Avatar
Post my car 427 RWHP what cluth i need?
i have camaro 98 M6 427 RWHP 383 TQ what i should install ? spec 1 good ?
Old 12-24-2007, 08:05 AM
02 BLK WS6's Avatar
If I were you, I would put nothing but a decent twin disk in there.
Old 12-27-2007, 07:55 PM
RareBreed0295's Avatar
If i was you i'd look into the Ls7 clutch. All i have heard is good things about the setup.
Old 12-27-2007, 08:29 PM
Snyper's Avatar
I should be making similar numbers before the 150 shot and im going LS7
Old 12-27-2007, 11:31 PM
Clayman's Avatar
I cant say I am a fan of SPEC clutches, I have heard a lot of bad stories. I went with the LS7 clutch/flywheel and it is awesome, only thing I dont like about it is it weighs the same if not a little more than the stock set-up, but thats no big deal at all. Engagement is right around the same spot as it was stock, and it still has a stock pedal feel, but it hooks really well.
Old 12-28-2007, 12:20 AM
venomhp's Avatar
ls7 would be a good clutch, but are you planning on doing many other mods because if you are then I would go with a stage II or III and get used to the pedal feel and do it right the first time.
Old 12-28-2007, 12:15 PM
raptorws6's Avatar
Texatralia
Old 12-28-2007, 12:33 PM
kyles2000z's Avatar
if you go with a spec, id go with a stage 2 + MINUMUM
Old 12-28-2007, 07:35 PM
Viper's Avatar
Clutchmasters. I'm putting down 431hp and it holds just fine for drag racing , autox and road race. Feels like stock. Get a new flywheel too, it makes a difference.
Old 12-28-2007, 08:55 PM
DarkJuggalo's Avatar
+1 for ls7
Old 12-29-2007, 02:23 PM
ls1 joe's Avatar
Spec Stage 3 is in our street cars. The one in now has about 400 passes on it and 40K plus miles. It is just a regular stage 3.
Amber
Old 12-30-2007, 08:36 AM
BlazinT/A's Avatar
i have a spec 3+ no complaints and im making 411 hp and 371 tq, been to the track a bit too
Old 12-30-2007, 09:32 AM
red99ls1ta's Avatar
ls7 clutch sucks ***. dont tell this guy to get it, he will smoke that thing doing any type of real launches.
specs are decent, i had a stage 3 in my t/a and it was great. textralia makes real good stuff too, expensive but good.
Old 12-30-2007, 10:21 AM
hz28's Avatar
+ 2 for that comment.
