How do you install the subthump passenger stealthbox?
I already have the subthump drivers stealthbox and amp rack, do I need to remove the spare tire jack in order for it to fit?
any thoughts guys?
Also, for you passenger stealthbox owners, how did you cut out the panel???
Your help is appreciated!!!
Carlos.
any thoughts guys?
Carlos.
i would assume you would lose the spare for the box but dont quote me. to cut that thickness of plastic me personally i would use an air saw. powered off an air compressor and looks like a tiny jig saw. they work great. an air cut off wheel would work great also. or dremel.
The Dremel will melt the plastic but it melts it pretty clean. Not really a Dremel's forte but it works surprisingly well and after you pull the melted plastic excess off (pulls off clean) you actually get a pretty nice edge from it... I personally hate cutting panels but I'm not nuts about bass... I'm going to do the single 10" and be happy.
