ATI balancer assembly question (pics)
Old 12-24-2007, 04:30 PM
sworaz's Avatar
Default ATI balancer assembly question (pics)
Just want to make sure I don't frick this up. Tell me if I have this thing together correctly... ATI's instructions blow. Thanks
I have the crank pulley on top of the hub (the shorter side) and the AC pulley coming up from the bottom side (like shown in the bottom pic) Do I have the AC pulley going on correctly?
Old 12-24-2007, 04:47 PM
sworaz's Avatar
This might be a better diagram.
Old 12-24-2007, 04:52 PM
1320's Avatar
Thats the only way it works......isnt it. I dont think you can get together another way.
BTW, did you find a good price on it?
Old 12-24-2007, 04:53 PM
sworaz's Avatar
Here's my finished product...correct?
Old 12-24-2007, 04:55 PM
sworaz's Avatar
Yeah I seemed to find a couple ways to put it together... This makes the most sense though.
I did get a killer price on it...even better than Summit. Lonnie's Performance rocks
Old 12-24-2007, 05:21 PM
forcd ind's Avatar
not sure on yours, but on the inside of my balancer (vette style 8 rib, a/c pulley delete) there was an alighnment marked that matched up with one on the hub-make sure if you have that, to line it up
Old 12-24-2007, 05:33 PM
sworaz's Avatar
Yes the balancer and hub both had a round etching and the directions said to line them up.
The only other thing that doesn't make sense to me is how the supercharger pulley is able to sit flush on the ATI balancer with the bolts sticking up off it.
Old 12-24-2007, 06:56 PM
platinum1's Avatar
looks right
Old 12-24-2007, 07:02 PM
kp
kp's Avatar
Depends whose pulley you have, the ATI balancer pulley has three bigger holes to clear the three bolts that hold the A/C pulley on and the other three attach it to the ATI damper.
Old 12-24-2007, 09:54 PM
DanZ28's Avatar
Those other 3 holes that attach the ATI pulley on mine are not drilled out like his is, don't need them but odd that some have then and some don't.
Old 12-24-2007, 10:32 PM
sworaz's Avatar
Actually I think I might have it wrong. The vortech pulley comes with 6 bolts (3 long and 3 short) they are just like the ones that came with the ATI dampner but longer. Do these longer ones replace the ones ATI sent?
Old 12-24-2007, 11:14 PM
kp
kp's Avatar
Probably, since the vortech kits are made to be used with an ATI damper.
The newer dampers only have three holes drilled, you were lucky to find one with the six holes. Maybe they started drilling all six again.
Old 12-24-2007, 11:44 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
For the 6 bolt Vortech
The longer bolts will go through to the AC pulley, replacing the ones ATI supplies.
The shorter ones bolt into the hub, in the 3 unused holes.
Feel free to contact me if you need any more info.
Happy Holidays.
Old 12-24-2007, 11:46 PM
sworaz's Avatar
So there is some of these dampners that only have the 9 holes drilled? Do you have to drill the other 3 or can you just run the 3?
For where i'm at: I have the 6 flat head screws and that's all I put on. Then I put the supercharger pulley on and run the remaining six bolts (3 long through to the AC and 3 short to the balancer) correct? For some reason I thought you put the other bolts on then mount the supercharger pulley on top of them...lol
Thanks for the help guys...enjoy your x-mas.
*edit* Thanks for the chyme in Lonnie. I'll give you a call if I run into any issues. Thanks again.
Old 12-25-2007, 12:51 AM
TT-TECH Veteran
Inspector12's Avatar
Well just saw the post I hope you got it figured out now.
Old 12-25-2007, 12:36 PM
sworaz's Avatar
I'm pretty sure I got it together. I haven't tightened any of the bolts yet or used locktite. How did you guys put the whole assembly on?
Seems like the easiest would be to just put the hub + AC pulley on and then bolt on the crank pully, then the supercharger pulley. Might be issues lining them up doing it this way. Has anyone put the entire assembly on all at once? Any tricks?
Old 12-25-2007, 09:02 PM
LS1TECH Sponsor
If you put the AC pulley & hub on the engine first, Then it is easier to torque all the balancer bolts with the engine holding it from turning.
Just do not forget to slide the AC pulley on first, or you will have to pull it back apart.
Old 12-25-2007, 11:22 PM
DanZ28's Avatar
Appears so as I only have 9 holes like KP mentioned. I don't need the other 3 as I don't run an ATI SC system where you need all 6 bolts, but if i did i would have to drill them out.
Dan
Old 12-26-2007, 04:52 PM
Jake@EPP's Avatar
Dan
That is correct, i cannot remember the last time i have gotten a balancer where all 9 were drilled.
I have taken a series of pictures and will post a write up as soon as a get a free second.
Quick Reply: ATI balancer assembly question (pics)
