Summit Radiator
Hey, didn't I just talk to you about motor mounts.
Is the radiator you have a Summit 380458? I thought you were using a Muncie 4 speed trans? The 380458 has the built in auto trans cooler. Suppose to be a direct fit for the Nova/Chevy II.
I think you did. I am using a generic Summit aluminum radiator since I am fabricating everything else I went with the biggest cross flow that would fit. Hot Rod did a test on them and they performed well.
