Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
big bang 305
Old 12-25-2007, 01:50 PM
drrobotnik's Avatar
Default big bang 305
Hey guys what do you suggest that i do to get the most bang out of my 305. it is currently a stock motor. I am planning to pull the motor soon and rebuild it but I dont want to have to do it more then once in a short amount of time. What are some good aftermarket parts to give it alot of power?
Old 12-25-2007, 02:09 PM
96lt1m6's Avatar
dont pull it out to rebuild it,honestly bro! get a 350 and build that and still drive the 305 around....why spend the same money for less performance?
Old 12-25-2007, 03:23 PM
drrobotnik's Avatar
yeah ive heard that from alot of people, and that is what i wanted to do from the beginning but people talked me out of it. if i were going to swap it with a 350, what should i do? another reason i was just gonna redo the 305 was because i have it already
Old 12-25-2007, 08:24 PM
96lt1m6's Avatar
350 all the way,the 305 is a good engine but will be more costly in the
what type of car is this motor being rebuilt for,whats the intended use etc.
most of all how much do you want to spend?
Old 12-25-2007, 08:37 PM
In-Zane Moderator
ZONES89RS's Avatar
Damn, you can pick up a 350 block for next to nothing. You can get a BS 350, 87+ with the roller tappets allready drilled, pick up the OE roller equipment off Ebay of a LT1 oit of a scrap yard. Then get the cheap *** LT4 hot cam, put whatever heads you want on it and it will run its *** off. But if you get vortec heads or some cheap SR torquers you would do WAY better.
BOOT to the 305.
Old 12-25-2007, 08:50 PM
ssean92's Avatar
look up tirdgenbum. I think that is what he goes by. 12's on a 305
Old 12-25-2007, 09:54 PM
drrobotnik's Avatar
its going be put into a 83 Monte Carlo and i want to keep it carb'd. i want to do it cheap but not dirt cheap. i can pick up a complete but disassembled 350 4 bolt main from this guy around me. the only prob i had was that i didnt want to have to buy an engine that needed to be pressure tested on top of what im already paying for the engine.
Old 12-26-2007, 03:28 AM
In-Zane Moderator
ZONES89RS's Avatar
Man, it is worth it to get a 350. A 305 can run, but a 350 will fly.
Old 12-26-2007, 12:50 PM
streetassasin's Avatar
Originally Posted by ZONES89RS
.......A 350 can run, but a LS1 will fly.
fixed for ya
I would try to find a used LT1 to throw in it
Old 12-26-2007, 01:49 PM
JUICED96Z's Avatar
Originally Posted by streetassasin
fixed for ya
Big block would fly even faster
For the cost of a 350 I would go that route man.
Old 12-26-2007, 03:09 PM
Burning Rubber's Avatar
fixed for ya
I had a 305 in my camaro and it ran 15.8 every time. Then I put a LT1 in it with a cam and headers and Its not even right yet and it ran 12.6. I think it was worth it to get a 350 instead of a 305.
Old 12-26-2007, 03:58 PM
drrobotnik's Avatar
trust me guys if i had the money i wouldve put in a 454 but im only 17 with an unsteady job. this is also my everyday car. im just wondering a cheap route to go alot faster.
Old 12-26-2007, 04:05 PM
Now you have my attention
GTOSE's Avatar
If you take your time and stick it out, you can have a very strong running motor in time.
Go 350 man, its a good investment.
Old 12-26-2007, 04:11 PM
drrobotnik's Avatar
what are the first things i should buy?
Old 12-26-2007, 07:20 PM
In-Zane Moderator
ZONES89RS's Avatar
fixed for ya
My 350 has been shitting on LS1s so i guess it flys too???
Just build a BS 350, you will be as happy as a pig in stank.
Old 12-26-2007, 07:41 PM
ssean92's Avatar
shoot just got to the parts house and get a reman engine for under 1k
Old 12-26-2007, 08:12 PM
In-Zane Moderator
ZONES89RS's Avatar
****, a place in Dalla Tx sell short blocks for 650 plus core. Thats 755 without a core for a short block with flat tops. Not a bad deal at all.
Old 12-26-2007, 08:38 PM
drrobotnik's Avatar
they guy around me that has the 350 4 bolt wants 100 bucks for it. its a complete engine but its disassembled. since thats in my price range and isnt far i think that im gonna pick that up.
Old 12-26-2007, 08:54 PM
In-Zane Moderator
ZONES89RS's Avatar
Do it, it will be worth you while, and dont look back.
Old 12-26-2007, 09:42 PM
drrobotnik's Avatar
alright thanks Z, what do you think would be the best parts to purchase for someone on a small budget?
