P1810?? Help
P1810?? Help
I recently did the a4->m6 swap and now I have this code pop up every other day. Is this code an a4 only code? If so, I can just turn it off in HP tuners.
I wasnt able to actually put an m6 tune on it, but I changed everything that needed to be changed. Is this one of those a4 only codes? If so, I'll just go back in and turn it off for good.
PO1810 code is a trans code. The Automatic Transmission Fluid Pressure Manual Valve Position switch (TFP Val. Position Sw.) consists of five normally open switches. Ignition voltage is applied to each of the switches. By grounding one or more of these switches with fluid pressure from the manual valve, the Powertrain Control Module (PCM) can detect which gear range is selected.
If the PCM detects an invalid combination of the TFP Val. Position Sw., then DTC P1810 sets.
Turn it off.
